Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-03-2005, 12:15 PM   #1
Mikez40
CF Senior Member
Mikez40's Avatar
Send a message via AIM to Mikez40
Default Flywheel Resurfacing question?
Ok guys, I am a little worried now. I just had my clutch replaced and they resurfaced the flywheel...Now I am reading in the C4 Tech section that you should not resurface the flywheel.
http://forums.corvetteforum.com/show...23&forum_id=48
So am I going to start having problems now? I have run the car up to 7000rpm's in 1st and 2nd with no noticable vibrations.
The trans guy told me that they put in shims to make up for the resurfacing so it would balance correctlly, if that makes a differance.
Am I worried about nothing or what?
thanks,
Mike
Mikez40 is offline   Reply With Quote
Old 05-03-2005, 12:19 PM   #2
8388
CF Senior Member
8388's Avatar
I would not resurface the fly wheel. If you already did, consider buying a new one, or more than likely you'll be r&r the tranny again. Most of the time they remove too much material in order to make it right.
8388 is offline   Reply With Quote
Old 05-03-2005, 12:30 PM   #3
Mikez40
CF Senior Member
Mikez40's Avatar
So how long will it be before I notice problems? I only put about 2000 miles a year on the car. But it goes to the drag strip 4 or 5 times in that year.
Old 05-03-2005, 01:31 PM   #4
RatRacer
CF Senior Member
RatRacer's Avatar
Just buy a new one while the ebay guy has them cheap. You are never supposed to resurface a ZR-1 flywheel.
RatRacer is offline   Reply With Quote
Old 05-03-2005, 01:37 PM   #5
Mikez40
CF Senior Member
Mikez40's Avatar
Well good news, I just called the transmission place, and talked to them and they said the same thing, You DO NOT RESURFACE (MACHINE FLYWHEEL). I just misunderstood what they told me. All they did was clean it up to take the surface dirt off it. NO MACHINING DONE. I feel much better now.
Thanks for the replay’s I really appreciate it.
Mike
Old 05-03-2005, 01:50 PM   #6
DDSLT5
CF Senior Member
DDSLT5's Avatar
Mike
LPE machined mine back in the day - made no difference whatsoever. Supposedly, there is a lip on the edge of the flywheel that makes take-up of the clutch smoother, and without it (after machining) the action is more abrupt. I didn't notice any problems.
DDSLT5 is offline   Reply With Quote
Old 05-03-2005, 01:56 PM   #7
Jeffvette
CF Senior Member
Jeffvette's Avatar
Location: No more yankee my wankee, the Donger is tired!
Jeffvette is offline   Reply With Quote
Old 05-03-2005, 03:15 PM   #8
DDSLT5
CF Senior Member
DDSLT5's Avatar
Quote:
Old 05-03-2005, 07:34 PM   #9
Jeffvette
CF Senior Member
Jeffvette's Avatar
Quote:
Old 05-03-2005, 08:43 PM   #10
415LT5-badZR-1
CF Senior Member
415LT5-badZR-1's Avatar
415LT5-badZR-1 is offline   Reply With Quote
Reload this Page Flywheel Resurfacing question?
Tags
03, c4, corvette, flywheel, resurfacing
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
c5 coupes typically leaky? LSUgoTIGER C5 General 24 09-07-2005 11:24 PM
Clutch problems Diagnosed - Warning - Large images fauxrs C3 Tech/Performance 11 09-17-2002 05:43 PM
Pilot bearing. To grease or not to grease. that is the question! MikeC C3 Tech/Performance 9 03-27-2002 08:13 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
