Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-02-2005, 10:16 PM   #1
LoTu5
CF Senior Member
LoTu5's Avatar
Default Gearbox questions.
Ime planning to refit the box back into the car tomorrow,should i put a dab of grease onto the nose of the shaft where i goes into the spiggot bearing,put a thin coating of grease on the shaft that passes thru the throw out bearing and dab some copper grease on the clutch fork ends where it touches the throw out bearing.
Thanx.
LoTu5 is offline   Reply With Quote
Old 05-02-2005, 11:14 PM   #2
4cefed
CF Senior Member
4cefed's Avatar
Send a message via ICQ to 4cefed
The throwout bearing ID and OD (where the clutch fork rides) should be lubricated along with the Clutch fork ball stud. Refer to Page 7C-12 Figure 11 (1990 Manual) with GM P/N 1052356
My manual says the pilot bushing is oil impregnated and I can not find a reference where it calls for lubrication on the input shaft nose or pilot bearing.
Not sure what copper grease is, I would use recommended lubricant.
__________________
Joel
90 ZR-1
415 LT5
"If a little is ok, then too much is just right!"
Big Daddy
4cefed is offline   Reply With Quote
Old 05-02-2005, 11:24 PM   #3
LoTu5
CF Senior Member
LoTu5's Avatar
Thats great Joel
Old 05-02-2005, 11:27 PM   #4
LoTu5
CF Senior Member
LoTu5's Avatar
Btw,over here we use copper grease in places like on the backs of brake pads to stop brake squeal,there's probably another name for it in the U.S.
Old 05-02-2005, 11:32 PM   #5
4cefed
CF Senior Member
4cefed's Avatar
Damn Cliff do you ever go to bed? It must be 3:30 in the am over there.
Old 05-04-2005, 08:07 AM   #6
andy190
Junior Member
Default never sleeps
he never sleeps he likes being awake at stupid oclock may be thats because somebody was messed his car up so much that he cant sleep
andy190 is offline   Reply With Quote
Reload this Page Gearbox questions.
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rear Diff questions mn_vette C4 Tech/Performance 9 01-26-2004 04:57 PM
A couple questions concerning 422 vs. 415 and different cams. wdo-mkr C4 ZR-1 Discussion 23 01-07-2004 10:12 PM
Buying 1990 Vette, couple questions 1989IROC C4 Tech/Performance 16 08-06-2002 05:18 PM
3.73 vs 3.90...0-60 & 1/4miles shift questions boblackhardtop C5 Tech 9 04-21-2002 04:48 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
