Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-02-2005, 04:45 PM   #1
lookingforvette
CF Senior Member
Default transmission gurus, advice needed
i took my zr1 to the dealership today.
i know most didnt like it but i trust the mechanic.
anyways my vacum problem was simple, the vacum line was disconnected from the throttle body, now the engine throws no codes.
everything else is solid, but my tranny does have a spun out bearing, and that has been the reason for my noise i have been hearing.
the dealership quoted me 700-800 dollars
6 to 7 hours of labor for the job, as i take the transmission has tobe taken off the motor.
does this sound right?
any ideas of getting it done cheaper?
and besides the noise will this have any ill effects on the tranny?
opinions from people who have had this issue with their tranny is appreciated
thanks
lookingforvette is offline   Reply With Quote
Old 05-02-2005, 04:56 PM   #2
91mongoose
CF Senior Member
91mongoose's Avatar
Send a message via Yahoo to 91mongoose
Depends on which bearing it is. If it's the tail shaft bearing you could remove the tranny and pull the housing yourself, have someone replace the bearing, and then do the reinstall work.
6-7 hours sounds about right - I can do a clutch change in 3-3.5 hours and I'm usually just about 1/2 chilton time.
91mongoose is offline   Reply With Quote
Old 05-02-2005, 05:09 PM   #3
lookingforvette
CF Senior Member
Default vette
dont know what bearing.
but i know i can get a new zf6spd on ebay or somewhere for about 1800 of course you got installation
is it worth it to pay this much just to fix the bearing.
whats the chances of one bearing getting lose and screwing up other parts of the tranny?
thanks
Old 05-02-2005, 05:15 PM   #4
FastZR1
CF Senior Member
FastZR1's Avatar
A new ZF6 for 1800 bucks is a good deal in my book, if in fact it is new. Make sure you know the difference between a blue tag and black tag ZF6. One was in the later model ZR-1s and one is stronger than the other. I don't have my notes here so I can't be exact on which is which.
FastZR1 is offline   Reply With Quote
Old 05-02-2005, 05:30 PM   #5
lookingforvette
CF Senior Member
Default thanks
but what is your opinion on the spun out bearing
have you had this problem?
what are the risk you are taking it driving it with this?
thanks
Old 05-02-2005, 05:36 PM   #6
8388
CF Senior Member
8388's Avatar
Are we talking bearings inside the tranny ? if so how did we come to this conclusion ? did the dealer change the fluid ? if so what did they find ?
8388 is offline   Reply With Quote
Old 05-02-2005, 05:40 PM   #7
lookingforvette
CF Senior Member
Default dealer
ugh, well thats just what the dealer said that one of the bearings is spun pretty badly
i took the car there for a few issues, and one was this transmission noise and this was thier opinion.
i dont know how they came to that conclusion.
what do you think?
Old 05-02-2005, 05:41 PM   #8
lookingforvette
CF Senior Member
Default inside
yes the bearings inside the tranny
Old 05-02-2005, 05:42 PM   #9
8388
CF Senior Member
8388's Avatar
Quote:
Originally Posted by lookingforvette
what do you think?
I think you need to first examine the tranny fluid before you start replacing things.
Old 05-02-2005, 05:45 PM   #10
264FPS
CF Senior Member
264FPS's Avatar
Sounds like the same problem I had in my 90
I believe it was the line shaft bearing which would make a screetch but only certain times
I had them replace the throw out bearing at the same time
They had quoted the job a 1000
It's a tough call but I will say that that did fix the problem with my 90 and it has been fine ever since - going on two years
264FPS is offline   Reply With Quote
Old 05-02-2005, 06:29 PM   #11
ZR WON
CF Senior Member
ZR WON's Avatar
Hmmm
Does it only happen when it's cold and you are letting the clutch out? Does it sound like a little dog barking when you do? If so, it's almost definitely the throwout bearing. You would have to take the trans out but I'm not sure it's worth it.
I've had my car for 6 years and it made that sound at first(hadn't been driven much in the 3 years prior). After driving it for a while, it stopped and hasn't done it since(knock on wood). Eventually you'll need to replace it but I'm not sure it's absolutely necessary at this point.
Brian A
90 ZR-1
12.09@118
01 Z06
not stock
ZR WON is offline   Reply With Quote
Old 05-02-2005, 08:29 PM   #12
lookingforvette
CF Senior Member
Default vette
it does seem happen more when its cold that when its warm
and i would maybe say it kinda sounds like a dog barking but not sure, kinda a whining, will have to listen next time it happens.
but it defintitly happens more when its cold
what part of indiana are you from zr1won?
thanks
Old 05-02-2005, 08:32 PM   #13
FastZR1
CF Senior Member
FastZR1's Avatar
From what you explain, I don't think it is a syncro in the tranny. I know you said bearing, but I have heard some people refer to the syncros as bearings.
If in fact you had a bad syncro in the trans, you would get a lot of grinding when shifting into a certain gear. Trust me, I know. It would also cost a lot more than you were quoted and take a couple days to do the work.
I think your problem is one of the above suggestions from what you have described. Again, I am not a C4 or ZR-1 expert, but I have been around a little bit.
If it is a throw out bearing, you don't need to open the tranny. Just a quick removal and replacement of the tranny to change the throw out bearing.
Old 05-02-2005, 10:00 PM   #14
ZR WON
CF Senior Member
ZR WON's Avatar
Looking:
We've exchanged a few PMs; I'm just north of Louisville, Ky. Did you join the ZR-1 Net Registry email list yet? I still say it's your throwout bearing and unnecessary to replace unless you just can't stand that little dog barking..
Brian A
90 ZR-1
12.09@118
01 Z06
not stock
Old 05-03-2005, 11:28 PM   #15
meshies
CF Member
meshies's Avatar
Send a message via AIM to meshies
changing the TOB is an easy DIY job (if thats what the problem is)... i suggest that you do it yourself and save some of your precious money...
meshies is offline   Reply With Quote
Old 05-04-2005, 01:43 AM   #16
91vetteboy
CF Senior Member
91vetteboy's Avatar
Good topic. My throwout bearing will be replaced on 5/10. Same symptoms. Just started recently with that unusual noise. $510 labor plus part. 5-6 hrs of work.
91vetteboy is offline   Reply With Quote
Old 05-04-2005, 11:16 PM   #17
mpkile
Junior Member
I have a 93 zf 6 speed that I have done the clutch job myself twice. It's not too bad to do yourself. I use Centerforce clutch and pressure plate. I only expect 20 to 30k miles from the set since my driving habits are very bad and it's all in town. As far as noise goes it may also be the dual mass flywheel, hope it's not they are expensive, that noise is mostly while at idle speed. If your problem is the slip yoke bearing that can be changed without removing the tranny. Remove the rear housing and inspect and replace the bearing if necesssary. If you have a noise/vibration while driving it could be the u-joints or driveshaft balance. Only use Spicer u-joints. I made the mistake of using Percesion u-joints and ended up with a bad vibration. The zf6 is not repairable cost wise and the dealer's will only replace them. The Chevy list price is over $5000 so stay away from that job. If you let you clutch go real bad you can mess up the tranny such that you might as well replace it. The synchro's and bearing kit is over 1,000 plus labor you are better off buying a new zf6. Here is a link to a zf6 dude www.zfdoc.com. Contact me for more info about your noise and I'll be glad to give you my opinion if you want
Mike
mpkile is offline   Reply With Quote
Old 05-05-2005, 02:26 AM   #18
webgear
CF Member
webgear's Avatar
Mike[/quote]
Mike,
Great info and link.
After reading that link, I am going to flush and test my clutch system asap as preventative maintenance.
__________________
Howard
90 ZR-1, blk/blk, orig. owner
webgear is offline   Reply With Quote
Old 05-06-2005, 12:14 AM   #19
mpkile
Junior Member
One way to tell if your clutch needs to be replaced is if you feal ANY resistance to going into reverse or 1st when cold or hot. My car with only 30k on a Centerforce dual friction had a hard time going in to 1st. You could actually feal the car moving forward from the synchro's working (not enough air gap any more). I replaced both the master and slave hoping that is was hydraulics but my clutch was just plane abused. Hey I had alot of fun but $570 for the "best" clutch hurts alittle when they only last 30k miles. Still watch the clutch hydraulics, like zrdoc says a bad clutch will screw up a good zf6 beyond repair!
Old 05-06-2005, 12:24 AM   #20
Mikez40
CF Senior Member
Mikez40's Avatar
Send a message via AIM to Mikez40
Quote:
I've got you beat, my clutch only lasted just under 20,000 miles.
I just had it replaced last week at the tune of $875.00 parts plus labor. If I had time I would of tried doing it myself, but with only a week till the ZR-1 Gathering I paid big time for it.
Mikez40 is offline   Reply With Quote
Reload this Page transmission gurus, advice needed
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
