Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-01-2005, 01:40 PM   #1
webgear
CF Member
webgear's Avatar
Default ZR-1 Engine Pre-oiler.
I always thought it would be a good idea to install a pre-oiler in my 1990 ZR-1. That way I could build some oil pressure before I start it. I was once told by an airplane mechanic that most of the wear on an engine occurs during startup and that having oil pressure before starting may greatly extend the life of any engine.
I never got around to installing one. I noticed that Summit carries a couple general purpose pre-oiler models.
Any comments and suggestions are appreciated.
Should I?
What to buy?
Where to buy?
Where to install it? (ZR-1's easy access to oil cooler line placement looks inviting to me).
Thanks,
Howard
90 blk/blk ZR-1, orig. owner
webgear is offline   Reply With Quote
Old 05-01-2005, 01:42 PM   #2
90 Corvette ZR-1
CF Senior Member
90 Corvette ZR-1's Avatar
Send a message via AIM to 90 Corvette ZR-1
I've seen the size of one that Summit sells. If you can find a place to install it, Id be impressed.
90 Corvette ZR-1 is offline   Reply With Quote
Old 05-01-2005, 07:03 PM   #3
TommyL
CF Senior Member
TommyL's Avatar
I once saw one installed right behind the front bumper infront of the radiator overflow tank. If I'm not mistaken it was in an old KOTH issue from the ZR-1 registry. The install looked very clean and supposedly worked well.
TommyL is offline   Reply With Quote
Old 05-01-2005, 08:05 PM   #4
xlr8nflorida
CF Senior Member
xlr8nflorida's Avatar
Quote:
Would be cool but could create problems if not installed or maintained properly.
Personally, I wouldn't worry about wear startup or otherwise, the motor is plenty capable of going 200,000+ miles without the luber.
xlr8nflorida is offline   Reply With Quote
Old 05-02-2005, 12:33 PM   #5
zr11990broken
CF Senior Member
I have the one from summit on mine I installed it in place of the windshield wiper bottle. Before I put it on the cams would rattle when you first started the engine afterword you heard nothing but purty music. I would bet you would save a lot of engine wear by installing one
zr11990broken is offline   Reply With Quote
Old 05-02-2005, 01:16 PM   #6
ZR1 MK
CF Senior Member
ZR1 MK's Avatar
I have a preoil pump, but you could also use an accumulator.
__________________
Mike Kryger
427 cu in LT5
cardomain.com/id/zr1mk
ZR1 MK is offline   Reply With Quote
Reload this Page ZR-1 Engine Pre-oiler.
Tags
engine, forum, oiler, pre, preoiler, summitt
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
