Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-30-2005, 11:18 PM   #1
slarson
CF Senior Member
slarson's Avatar
Default Oil Leak
My ZR-1 arrived today in heavy rain. The car is beautiful inside and out.
I drove it about 30 miles but was not able to open her up due to the rain. When I got it home I notice the smell of oil, I parked the car then backed it up and found a puddle of oil. I'm not sure where is it coming from. I plan to put it on ramps tonight to get a better look.
I'm new to the ZR-1, are oil leaks common on a ZR-1? Does anyone have any ideas on where oil might be coming from?
Thanks...
slarson is offline   Reply With Quote
Old 04-30-2005, 11:34 PM   #2
LowFlight
CF Senior Member
St. Jude Donor '03
Senior Member
Cruise-In V Veteran
LowFlight's Avatar
Location: If you no longer go for a gap that exists, you are no longer a racing driver. Senna
lowflight
It could be coming from the oil pan where the bolts commonly loosen. If it is from the VERY front of the car..it is the lines that go in and out of the oil cooler.
LowFlight is offline   Reply With Quote
Old 05-01-2005, 12:13 AM   #3
slarson
CF Senior Member
slarson's Avatar
Quote:
It seems to happen when the car is running and not in the very front. It was also on a trailor for 7 days an 2400 miles, maybe something loosened up.
Old 05-01-2005, 12:36 AM   #4
LoTu5
CF Senior Member
LoTu5's Avatar
Quote:
Another common place is the oil idiot light sensor located on the under side of the oil filter housing just behind the frame where the passenger side Upper A-arm bolts to.
Its a right SOB to get too if it needs changing ,pull the plug of the end of the sensor run the motor and watch with a torch(flashlight) and watch for a steady oil drip,they dry up in the middle and crack thru the heat and you will be surprised how much oil will leak from it.
When i was looking for a leak i used a small mirror on a telescopic rod to examine some of the tight areas around the sump,front cover and front crank seal,good luck.
LoTu5 is offline   Reply With Quote
Old 05-01-2005, 01:03 AM   #5
slarson
CF Senior Member
slarson's Avatar
Thank You,
Looks like I'll be under the Z Sunday morning, I'll post what I find.
Old 05-01-2005, 11:11 AM   #6
TommyL
CF Senior Member
TommyL's Avatar
When I first purchased my 90 it leaked alittle oil that covered the passenger side floor pan. I couldnt find where it was comming from. I looked and looked, tightened up the pan bolts "they were lose", changed the oil lines, new sensor...still leaked. Turns out that whoever assembled the oil dipstick tube into the block at the factory, put "2" oil seals (instead of 1) on the end of the tube causing a leak. Removed the tube & both seals, put a new one on the tube, reinstalled and voila leak fixed. If you find this to be the problem, you will have to remove the inner wheelwells to access the tube. Just my .02
TommyL is offline   Reply With Quote
Old 05-01-2005, 12:21 PM   #7
ZR1991
CF Senior Member
ZR1991's Avatar
Hers another one.
A common leak that shows up after the car has not been driven, and results in "oil smell", is a pair of bolts, one on each side, in the center of the exhaust manifolds.
Problem is, their threaded holes go straight through to oil galleries, and when the seals fail after a few years, the leak occurs and reveals itself pretty much as you describe.
I had one on the left side. It is hell to get to, but if you re-seal it according to the service bulletin, it is a fix.
I have not seen mention of it here in a long time, perhaps others can jump in and direct you to more info.
By the way, if you drive the car often, the leak "appears" to stop, because the oil stays burned off the manifolds, but it is still there. It shows up after inactivity because that is what allows enough oil to be collected on the manifolds to be noticeable.
Good luck, let us know what you find.
Regards,
__________________
Art in Baton Rouge
"May The Horsepower Be With You."
2002 Red Z06, Black-Red Interior, stock.
I really miss these three:
1991 Red ZR-1, Saddle Interior, stock (sold 2008);
'63 Red on Red Split Window Coupe (sold in 2003),
1965 Shelby AC Cobra, Retired bracket racer replica, endorsed by Shelby (sold in 2003)-
ZR1991 is offline   Reply With Quote
Old 05-01-2005, 12:27 PM   #8
ZR1Blex
CF Senior Member
Your oil pan bolts are the first thing I would check as the LT5's vibrations shake them loose. I recommend buying a 1990-1993 GM LT5 Shop manual supplement as it lists the torque specs for the oil pan bolts. Occasionally torquing down your oil pan bolts will help preserve the oil pan gasket. I have had no oil drips ever since doing this.
ZR1Blex is offline   Reply With Quote
Old 05-01-2005, 12:27 PM   #9
lookingforvette
CF Senior Member
Default vette
no leaks on my 91, knock on woood.
lookingforvette is offline   Reply With Quote
Old 05-01-2005, 12:40 PM   #10
phrogs
CF Senior Member
phrogs's Avatar
Ok check all of the above but first things first.
If your car has the original oil cooler hoses on it they leak bad.
if the leak is at the back of your motor at the drian tube then I would say it is your breather box that is on top of the motor my bolts were all loose on that so I changed the gasket and locktighted the bolts.
but your best bet to find the source of your leak is to go to auto zone get a dye that you can put in the oil run it then you use a black light to find exaclty where the leak is coming from its a UV dye that is compatible with your oil and is for this exact test to find the source of your leak.
Because you could have oil spots all of the motor youll try all day to find the leak..
anyway good luck with it
phrogs is offline   Reply With Quote
Old 05-01-2005, 01:18 PM   #11
ZR-71
CF Senior Member
ZR-71's Avatar
Quote:
Mine too. Never had an oil leak and I hope it stays that way.
__________________
1991 ZR-1 Blk/Blk #2027
ZR-1 and SR-71: World Speed Record holders
ZR-71 is online now   Reply With Quote
Old 05-01-2005, 08:54 PM   #12
slarson
CF Senior Member
slarson's Avatar
I was unable to jack up the car (these cars are low). I need to find better ramps. The leak is definitely coming from the middle of the car and only leaks when driving or when it’s parked on a hill facing up.
It sucks because I just got the car yesterday and can't drive it without it smoking.
Old 05-02-2005, 01:00 AM   #13
LoTu5
CF Senior Member
LoTu5's Avatar
I put down 2 flat pieces of wood and roll the car forward onto them to enable clearance for jacking the car up,dont forget that oil has a habit of traveling away from the point of its leak,it can some times mislead you
Old 05-02-2005, 05:52 AM   #14
Jeffvette
CF Senior Member
Jeffvette's Avatar
Location: No more yankee my wankee, the Donger is tired!
Use the wood as Cliff suggersted to raise the car up a bit, then jack it. Take some brake clean and wipe down the oil pan and surrounding areas. Drive for a bit then park and then jack again to help locate the leak.
As suggested earlier
Oil pan bolts
Oil Temp sensors (there are two of them)
Center exhaust manifold stud
Those should be your three primary places to look.
Jeffvette is offline   Reply With Quote
Old 05-02-2005, 08:55 AM   #15
phrogs
CF Senior Member
phrogs's Avatar
I bought a 2 ton floor jack at sears and its for trucks and I have no problem getting it under my vette...
you need to get a good jack with stands and forget about the ramps
Old 05-02-2005, 10:57 AM   #16
Greybeard ZR1
CF Senior Member
Greybeard ZR1's Avatar
In addition to the above mentioned places, there is a small plate (with 2 bolts) on the lower pass. side of the block, just forward of the front of the oil pan. These bolts sometimes need tightening.
But pray it's just the foward,(little), oil pan bolts. they are the easy to get to. the other locations can be a royal PITA.
Greybeard ZR1 is offline   Reply With Quote
Old 05-07-2005, 01:52 PM   #17
slarson
CF Senior Member
slarson's Avatar
Finally Got the car up today but no engine oil leak, looks like it is coming from the transmission, not sure where though. I cleaned the bottom of the entire engine and Trans, checked fluid levels and added dye. I'm going to run it for 100 miles and then use an ultra violet light to find out where the leak is. I have never worked on a trans leak before, I'm hoping its the speedo O ring.
Old 05-17-2005, 01:05 PM   #18
slarson
CF Senior Member
slarson's Avatar
Default Update
Found the leak, it's coming from the middle trans gasket. Have to drop the trans to repair. $1000.00 parts labor
Old 05-17-2005, 01:30 PM   #19
UKZR1
CF Member
UKZR1's Avatar
Are you sure its not leaking out of the 'V' drain at the back of the block?? The bolts holding down the crankcase vent cover are know to work undone. There will be oil in the V that will drip through the drain at the back of the block. Shine a light under the plenum and see if there is a wet oil mess undeneath.
On the subject of oil leaks, I need some help as well. Mine looks to be leaking out of the bottom power steering pump mounting bolt. Is this posible?? Cliff, we spoke over the phone about this ages ago when you were working on yours. I cant remember the outcome.
UKZR1 is offline   Reply With Quote
Old 05-17-2005, 03:17 PM   #20
slarson
CF Senior Member
slarson's Avatar
Definitely the Trans, I used trace dye and ran it for 100 miles then shinned a UV light and bingo the case halves seal is blowing oil.
I do not have to knowledge to repair a ZF Trans, so I made an appointment at a GM service shop. The good news is the dealer I bought the car from is willing to pay for the repair.
Reload this Page Oil Leak
Tags
1965, 1984, back, corvette, engine, leak, oil, sensor
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rear end oil leak Top Cat C6 Tech/Performance 11 03-29-2005 04:22 PM
Internal Engine Oil Leak: Still Diagnosing... TedH C3 Tech/Performance 35 02-18-2004 08:54 AM
Internal oil leak Dyna C1 & C2 Corvettes 48 01-21-2004 08:58 PM
Oil leak *picture* GrandMasterFlash C5 Tech 11 12-27-2003 03:25 PM
Why has Chevrolet let this oil leak at the differential go on for such a long time? VETFVER C5 Tech 31 05-20-2003 12:14 AM
Huge disapointment-Car delivered today with bad oil leak-Please help me sleep tonight hudman C3 Tech/Performance 37 06-07-2002 12:54 AM
'Vert goes in for an oil change, comes out with an oil leak! The One C5 Tech 30 01-18-2002 11:35 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
