Heater blows cold air when car is not moving
Old 01-21-2005, 12:51 PM
ir0nmaiden420
ir0nmaiden420's Avatar
Location: Sarcasm. Just one of the many services I offer.
Default Heater blows cold air when car is not moving
My heater blows out hot air when i am driving but if I am sitting still at a stoplight or even when the car is stopped while warming it up, only cold air comes out of the vents. it is only when I start moving again that the air heats up again. This happens even when the coolant is 200 degrees, so the engine is not cold.
I have always thought that the air was not very powerful coming out of the vents as well, compared to other cars I have had.
Old 01-21-2005, 12:57 PM
redvette6spd
redvette6spd's Avatar
check your water level may be low
Old 01-21-2005, 01:18 PM
GT4DD
GT4DD's Avatar
This happens to me, as well... and I know my H2O is full.
Old 01-21-2005, 07:24 PM
jackdaroofer
Support Corvetteforum!
jackdaroofer's Avatar
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Low coolant is certainly a suspect with any heat/cool condition, but
There is a "door" that opens and closes at the heater box to close off or allow cold air. The door is controlled, I believe, by the temp controls on your heat/ac switches. The vette circulates coolant continuously through the heater, it's the door that controls the temps, I believe
Sounds like you need outside air pressure to open the door and allow heat, which means that at standstill the door is closed regardless of your control settings
How fast does the heat start back when you start moving and at what speeds? Not sure that will contribute to a solution but
seeya
Old 01-21-2005, 11:27 PM
thmupr
thmupr's Avatar
Must be a C4 thing.. Mine does it too... Got worse after I changed the water pump and did the TB bypass..
Old 01-22-2005, 10:12 AM
nobodyunknown
nobodyunknown's Avatar
That door works off of vacume.
Try this not moveing but raise the rpm in neutral.If that helps then it could be a vacume leak.
The door actuator has a vacume diaphram mabey a small hole in it.
Old 01-22-2005, 11:26 AM
Mr Mojo
Elite Torch Red Member
Mr Mojo's Avatar
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
That was my problem.
Old 01-22-2005, 07:48 PM
SurfnSun
SurfnSun's Avatar
St. Jude Donor '10
as said above youre probably low on coolant or have a big bubble in your system. Could be the heater control valve too. It has to be one of the two.
Old 01-25-2005, 02:02 PM
ir0nmaiden420
added some coolant and that did not solve the problem...
how do I change the heater valve?
Old 01-25-2005, 05:00 PM
SurfnSun
SurfnSun's Avatar
St. Jude Donor '10
How much coolant did you add? Was the radiator low when you opened the cap?
One way I fill mine is to start the car, open the cap, and start a slow rev using the throttlebody. When the coolant drops as the revs go up keep adding coolant til full. That will help get most of the air out of the system.
Old 01-25-2005, 05:07 PM
SurfnSun
SurfnSun's Avatar
St. Jude Donor '10
How low was your coolant level/how much did you add?
here is the way I add coolant to make sure its full.
Start the car, make sure its warm and thermostat is open. Open the rad cap and fill it up. Using the throttlebody start a slow steady rev of the motor. When the coolant drops in the radiator fill it up. Do this until adding more revs doesn't really drop the coolant level. The put the cap back on before letting off the throttlebody. That should help get most of the air out of your system.
Old 01-25-2005, 06:14 PM
dand1892
dand1892's Avatar
same problem have wondered but always forgot to post thanks
Old 01-25-2005, 06:23 PM
nobodyunknown
So you dont think its vacume related?
To Heater blows cold air when car is not moving
Quick Reply: Heater blows cold air when car is not moving
