Shock Purchase Question-Bilsein Z51 vs regular
Old 01-17-2005, 09:43 PM
C5Jimmy
C5Jimmy's Avatar
Default Shock Purchase Question-Bilsein Z51 vs regular
I am in the market for new shocks. (I'm gonna change them with the new poly bushings)...I'm set on getting Bilsteins, however are Bilstein Z51 shocks overkill for a car with regular suspension?Will they not "agree" so to speak with the car? I have a '92 vert, and am wondering if I should go with regular Bilsteins or Z51 Bilsteins? I know the car is designed with the suspension it has, I dont want to add the Z51's and "upset" the balance, however if they will compliment the suspension, then I would like to get them! Thanks for any replies!!!
Old 01-17-2005, 09:56 PM
xs650
Support Corvetteforum!
xs650's Avatar
I put Z-51 shocks on my 96 vert with standard suspension. It was a bit harsher than the stock worn Bilsteins but not very noticeable most of the time. Response and general handling improved quite a bit. I like 'em.
Old 01-17-2005, 10:46 PM
C5Jimmy
C5Jimmy's Avatar
Thanks for the reply! i'll go with them then...!
Old 01-18-2005, 06:48 PM
CF6873
CF6873's Avatar
I just ordered the Z-51 Bilsteins for my 94. I'll let you know how I like them.
Old 01-18-2005, 08:19 PM
jackdaroofer
jackdaroofer's Avatar
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I run the Z51's on my 88 Z52, I have 30mm solid front and 24 mm solid rear sway bars!
Great combo!
seeya
Old 01-18-2005, 08:44 PM
vader86
vader86's Avatar
Received 1,400 Likes on 1,016 Posts
Z51 shocks will work just fine on a base spring setup, it'll improve the handling.
Old 01-19-2005, 10:47 PM
CF6873
CF6873's Avatar
My Z51 shocks arrived today and my 30mm front sway bar got here yesterday. I can't wait for it to stop snowing.
To Shock Purchase Question-Bilsein Z51 vs regular
Quick Reply: Shock Purchase Question-Bilsein Z51 vs regular
