C4/Ford 9" 4 link project
After breaking a u joint, several halfshafts, and finally blowing the whole damn D44 case in half, I have gone to a 9". I am just finishing up the interior, everything else is done. I went with all Strange parts, 35 spline race axles, Strange ultra case, a Lenco locker, QA1 coilovers, and a chrome moly 4 link. If the locker gives me problems, I will go to a spool. I reused my stock rear brakes after making a caliper adapter to go between the Strange caliper bracket and the stock calipers. I did have to eliminate the ABS since there is no real place to mount it, and it wouldn't work anyways with the Ford 9". This is a street car, but I mainly use it for drag racing. I am still running a full exhaust, so I had to do a few things different than if it was an all out race car without an exhaust.
Thanks to Hooked Up (Dave) for some idea's for the car, and thanks to Bowtie8 (John) for help with the pictures. There will be more pictures added as it progresses.
Here is the link to the pictures: http://bowtye8.tzo.com/bowtie8/corve..._%20InchTN.htm
man that is crazy . wow i dont see myself cutting the car up like that , why didnt you go with the way hoover did ? what the price on a setup like that if you dont mind me asking . looks bad ***
Former Vendor
Look pretty COOL. Thanks for the sneak peak before.
Sure would like one of them in my car also. Just not enough time to do it myself and not sure I want to drop another 5K into it.
How much ground clearance do you have with the tranny brace? And could you get some more shots of how you wound up routing the exhaust around the rear components. I suppose with the removal of the ABS and other items you gained some clearance. It would be very tough with the ABS still in place. At least I would think so.
Good Job none the less. There is A LOT of work there, and the ETs will reflect it.
curious what you were running last year? And was this the only change with the rear for this year?
I hope it was, I would like to see a comparison of what somebody would do with that conversion as the ONLY mod.
Looks Great Jim
You'll be one of the first to rip off some 1.4s and 1.3's 60fts with a ZF.
I'll have all the scoop on the 4L80E when your ready to drink coffee going down the track.
John
John
Thanks Guys. I ran 10.72@132.45 w/1.56/60 last year. I hope to run in the 1.4's, and hope to get in the 10.50's. My previous best 60 ft was a 1.52.
Ski, the crossmember is 1"x2", and is about 1/4" below the exhaust. So it's hanging down about 1 1/4". I was really thinking about running it inside the car, but it would be a nightmare to make it fit around the exhaust. Since those pictures were taken, I have added some supports off the crossmember to make it more rigid. John now has the latest pictures, and they will probably be added soon. It isn't a daily driver, but I will have to be a little careful with the ground clearance.
For now I am running a 4" bullet muffler that dumps in front of the rear end. But I will probably run it to the back of the car. There should be room to Y the single 4" into dual 3" pipes, and run them under the axle tubes. The main reason I used a panhard bar over a track locator was for exhaust clearance. Same reason I didn't add a 1 1/4" tube under the housing from one 4 link bracket to the other. I just want to get the project finished, and I will probably redo the exhaust later.
I also have thought about seeing what difference this has on my et. I was planning on pulling my ac, ps, and adding an electric water pump, but I may have to postpone it to see what this mod does by itself.
1 Post
Jim, looks great. Holler at me when you get the chance.
-Jeb
Originally Posted by jburnett
Because Hoover's car as cool as it is and as nice as the "bolt-in" 9" was it isn't really optimum. You cannot get the instant center or other driveline geometry correct with 4-link bars that short.
-Jeb
-Jeb
Jim, you're almost home........good luck buddy. I wonder how long it will take before i'm buying that off ya....LOL. Probably cost a fortune to ship across the country, but i feel like i'm rebuilding your car here in NY, one piece at a time
Former Vendor
Thanks for the information! Yeah if you can, it would be awesome to see that as the only difference and how much ET you gain. I will be a solid .3-.4
It has to be WAY WAY more efficient than the IRS system.
Next time some of you are board in the garage - take a ratchet universay and put it on a drill, and run it at an angle. It will GLow red hot. All those angle, result in friction, and power loss. NO GOOD FOR MAX. POWER.
Great job, I know how much work that must have been and pictures alone, don't capture all the sweat, blood and tears.
That's a great looking job,
Way to go JIM!
Good to see you almost there, it's been fun being able to help and still stay clean
I know there were times when you thought "what have I done to my car?", now it's all worth it.
Looks great, Dave
Won't be long 'til you launch like this:
Looks great, Dave
1 Post
do you have to use a 4 link set up ? can you just run a 9inch with coil overs and Trq arm like the f body?
-Jeb
