Coolant leak diagnose...how to check for head gasket
having a leaking coolant system is not fun as the best of times.. this thread for problem heres how i found the leak:
1.. did a coolant pressure test...
2.. use the Universal Block Leak Test kit...
3..inspected plugs 5&7..why? becuz of the issue with GM in 89-90
this simple test will tell you immediately if there is a combustion leak check it out here: universal combustion leak tester Uniserval Block test KIT and here for instruction: hot to test for leaks
in my opion, pressure testing the system will tell you if you have a leak.
The Block Check is A positive solution to gasket failure ( if there is one)where by it detects combustion gases and can be used to pin point which bank has failed...i hope this helps all those that are having trouble with cooling system and suspect head gasket failure in thier 89-91 L98
happy hoildays to all
Originally Posted by siggy_freud
Looks very interesting indeed. However I am trying to locate a price for the kits. I cant find any information on pricing anywhere on the site. Am I missing something?
Thanks.
Thanks.
2.. inspected plugs 5&7..why? becuz of the issue with GM in 89-90
3.. A compression test.
Too bad that you have a head gasket to replace, but it's good you know what the problem is.
RACE ON!!!
Originally Posted by CFI-EFI
That is all good information. Another route that could have been taken is:
RACE ON!!!
RACE ON!!!
Ps: upper head gasket kit on it way.. just got to pick it up. i think the price for it was around C120.00$...but this time my buddy is ordering it at wholesale .. he claims it should only cost about C50 - 60 $.. we'll see
happy holidays to you and yours
Originally Posted by Fartleker
I'm currently in the process of changing the same thing. Good luck!
i have ordered these:FELPRO
350 ENG 5.7L 1987-1993 1986(Except VIN J,P) Corvette with aluminum heads
Use Head Set HS7733-PT-9 & Conversion Set CS8510 for complete rebuild 1ea.
HEAD BOLTS & INTAKE MANIFOLD GASKETS FOR TPI CAMARO NOT INCLUDED
$69.88 $16.01... FPP-1010 head gasket is included in this kits
Originally Posted by Evan Ginsberg
I do the block test first, they cost $10 at any parts store and tell you in 5 minutes if you have HCs in the water. No HCs, no HG or block crack etc.
HAPPY NEW to all!
1 Post
I got the HS 7733 PT-15 gasket set just so you know. Has intake manifold, exhaust manifold, head, and valve covers. Set me back $59.99 at Checker.
Edit: I also had to buy the intake runner gaskets. Those were $12 at Pepboys.
happy holidays
