Pics of lowered C4's with 315's in the rear please?
Old 12-03-2004, 01:14 PM
jp2002ls1
jp2002ls1's Avatar
Default Pics of lowered C4's with 315's in the rear please?
I have been thinking of lowering my car and have been debating over the loss of clearance which would make it harder to go up driveways and such or lowering it and getting better handling and a better look. I have 11" wide rims in the rear and would like to see some pics of a lowered C4 with 17X11's in the rear with 315/35/17 tires.
Thanks.
Also do any of you guys who have lowered their vettes have any comments or troubles after they lowered their car? I live in Michigan and our roads are full of potholes so I want to make sure it will retain its ride quality, as it is the front air dam scrapes every time I drive up a driveway. I have many suspension mods and I figure lowering it is the last step for better handling. Thanks for any comments/suggestions.
Old 12-03-2004, 02:31 PM
Mav85vette
Mav85vette's Avatar
I have and 85 lowered with 315's in the back. I dont have any pictures but I dont have any problems driving around. I too live in michigan, the pot holes are a pain, but i dont have any clearance issues thus far. My car is lowered about 1.5 to 2 inches all the way around.
Old 12-03-2004, 02:45 PM
VR'92
VR'92's Avatar
Location: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
IMHO I think Lowerd vette's look great! Problem is I don't have the guts to do mine cause I'm already scraping like crazy at the stock hieght around here. (N. Alabama)
Old 12-03-2004, 09:53 PM
#70SM2
#70SM2's Avatar
Thanks.
Mines lowered a lot, sorry don't have any good pics from rear, but I'll get some this weekend at California Speedway. Although I've gone to 335's on rear 315 front. Lowering the car was the best handling mod I've done to date. You do have to be carefull in certain situations street driving, but so do most of Ferrari guys, my height same as my friends 360 spider .. lower is better .. also seems to have tightened suspension like the spring rate's on Z51 ..
Old 12-03-2004, 10:26 PM
FastZR1
FastZR1's Avatar
Lowered with 315's in the back.
Old 12-03-2004, 10:54 PM
Steve85
Steve85's Avatar
Cruise-In V Veteran
Here is my 85 lowered with 11" rims, AFS package with Dunlop 315's (geee, you don't see that here often )
IMO, It is a perfect fit, tire & body close and the sidewall right to the very edge, so close that the sidewall protrudes (1/8" ) but the tread does not.
Obviously you will scrape that front spoiler more often, but you scrape it anyway, so it will never look new. Replace it when necessary, maybe every other year.
Old 12-03-2004, 10:57 PM
DieL
DieL's Avatar
I have a 93 with 19x11.5s in the rear. running 305/30/19 pirelli rossos on them. car is lower than any other c4 out there ( most likely ). doesnt rub one bit but i do have z07 springs, and custom valved (stiff) bilsteins with shortened shafts. and bigg sway bars... so basically its quite stiff so theres not much room for the suspension to drop enough to rub.
Old 12-03-2004, 11:56 PM
1985 Corvette
1985 Corvette's Avatar
It probably just isn't my day for catching onto to something everyone else might know but, how in the heck do you have 11's in the back without fender flares?
Old 12-04-2004, 12:03 AM
jpee
jpee's Avatar
You can buy aftermarket 17x11 with a larger offset (56mm) & they will fit.. I have them on my 96 take a look..
Old 12-04-2004, 12:08 AM
LD85
LD85's Avatar
Old 12-04-2004, 02:06 AM
Mo_Bandy
Mo_Bandy's Avatar
check my website....
Mo
Old 12-04-2004, 04:18 AM
VetteNoob
VetteNoob's Avatar
315s lowered with new poly bushings.
Old 12-04-2004, 05:41 AM
jerkyboy
jerkyboy's Avatar
I've dropped mine too. I will say that if you have vert with an x brace, you will hit it a lot. I also seem to hit my header collectors as well. I wouldn't trade the stance though!!
Old 12-04-2004, 03:00 PM
jp2002ls1
jp2002ls1's Avatar
Thanks for the pics and info guys.
I believe the consensus is that it improved the handling a significant amount and makes up for the lack of ground clearance right?
I already have the Z51 suspension (stiff springs/big solid sway bars), New Bilsteins, all poly bushing throughout, camber brace, 17's, etc..... The C4 handles better than almost any car I have driven but I think I will be lowering it next to get better handling because I want the best handling I can get out of my car.
Any more suggestions?
Old 12-04-2004, 08:15 PM
djxib
djxib's Avatar
Mines lowered with coilovers and 315's on the rear. Like he said - I hit the cross-brace if I am not careful, but wouldn't trade the look!
Old 12-04-2004, 08:29 PM
Bruce
Bruce's Avatar
Djxib
just send you a private mail.
Bruce
Old 12-04-2004, 08:39 PM
Bruthish
Bruthish's Avatar
St. Jude Donor '03-'04-'06-'08-'09
To Pics of lowered C4's with 315's in the rear please?
Old 12-04-2004, 11:38 PM
Mo_Bandy
Mo_Bandy's Avatar
The only thing I could add would be you may want to recheck your alignment afterwards, your tires will otherwise wear more on the inside...
Mo
Old 12-05-2004, 01:10 AM
Saleen Grunt
Saleen Grunt's Avatar
Thanks.
Just some FYI:
despite popular belief, lowering your car will not improve its handling charactoristics. It will completely offset factory suspension geometry (which we assume is correct for a car like this).
Unless you really redo the factory geometry, lowering is almost always a bad idea.
Old 12-05-2004, 08:45 AM
Nathan Plemons
Nathan Plemons's Avatar
You're gonna get flamed for that one, but I'll take it with you. Although lowering the car might improve some aspects of handling it will likely adversely affect others.
Honestly though I can look at most of these pictures of lowered C4's and they don't really look any lower than mine, and I know mine is factory ride height. "The Look" looks just the same to me, and I never scrape my headers. To each their own I guess.
There are a few out there that are completely slammed, which just makes the car impractical.
Quick Reply: Pics of lowered C4's with 315's in the rear please?
