Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-24-2001, 06:22 PM   #1
westifer
Junior Member
I have just purchased an '89 convertible with an L83. The car looks great and has 98K miles. What would be my best use of approximately $500 for performance upgrades?
westifer is offline   Reply With Quote
Old 07-24-2001, 06:28 PM   #2
FU
NCM Lifetime # 982
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14
Support Corvetteforum!
FU's Avatar
Location: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY The Surcharge State
NO2
FU is offline   Reply With Quote
Old 07-24-2001, 06:43 PM   #3
Monty
CF Senior Member
Monty's Avatar
L83 is the RPO for a Crossfire Injected motor used in 82 and 84 Vettes, and F-body's.
Sure you don't mean L98?
Monty is offline   Reply With Quote
Old 07-24-2001, 06:48 PM   #4
westifer
Junior Member
Hmmm -
My VIN is 1G1YY3183K5nnnnnn and I thought the 8 was a reference to the L83, but I now see it was L83 and L98 ! - Live and learn!
Old 07-24-2001, 07:03 PM   #5
scorp508
CF Senior Member
scorp508's Avatar
Yep... that K in your VIN means 1989. Click the image to open in full size.
scorp508 is offline   Reply With Quote
Old 07-24-2001, 07:33 PM   #6
GiDvEtTe84
CF Senior Member
GiDvEtTe84's Avatar
Send a message via AIM to GiDvEtTe84
I was wondering...... Click the image to open in full size.
GiDvEtTe84 is offline   Reply With Quote
Old 07-24-2001, 07:47 PM   #7
john25
CF Senior Member
john25's Avatar
March 3-pc Power & Amp pulleys & belt. $150
Crane adj. fuel press. regulator. $70
Air Foil & K&N air filter. $110
High flow Catco main cat. $110
Pacesette dual Monza tips in place of mufflers. $85
Port plenum and gut the pre-cats.
This is a little over $500 but you'll be happy with the results until you can get more involved than bolt ons. If you want sources for these parts e-mail me. Don't forget a good set of ignition wires, plugs, wires & cap & rotor.
john25 is offline   Reply With Quote
Old 07-24-2001, 07:55 PM   #8
JOHNL
CF Senior Member
JOHNL's Avatar
You tricked Me Click the image to open in full size. I was thinking X ram (Crossfire)
JOHNL is offline   Reply With Quote
Old 07-24-2001, 08:10 PM   #9
89C4L98
CF Senior Member
89C4L98's Avatar
Yea what john25 said. Plus you can gut your air pump, tb bypass, open air filter lid. Which are all "FREE" mods.
89C4L98 is offline   Reply With Quote
Old 07-24-2001, 08:17 PM   #10
scorp508
CF Senior Member
scorp508's Avatar
Quote:
Originally Posted by john25:
[B
[/B][/color]
Ditch the air foil, worth nothing.
K&N Filter : $50
Open Air Lid : $0 (Cut it yourself)
Cut Spark Plug Electrods : $0
Adjust TPS to 0.68v at idle: $0
2pc Underdrive Pully Kit: $100
Breathless Vortex Rammer: $250
Hi-Flo Catalytic Convertor] $100 (I think)
Old 07-24-2001, 10:49 PM   #11
BBA
CF Senior Member
BBA's Avatar
Send a message via ICQ to BBA
Headers.
BBA is offline   Reply With Quote
Old 07-25-2001, 12:19 AM   #12
Dark Side
Junior Member
Quote:
Originally Posted by 89C4L98
Yea what john25 said. Plus you can gut your air pump, tb bypass, open air filter lid. Which are all "FREE" mods.[/color]
How do you gut your air pump?? will this work on an 85?
Jim
Dark Side is offline   Reply With Quote
Old 07-25-2001, 02:40 AM   #13
westifer
Junior Member
These are good suggestions. I'll start with the no cost stuff and go from there. It sounds like the filter should be one of the first purchases!
Can someone help with detail on:
Open Air Lid description
Thanks for the suggestions! I'm ready to tweak this ride!
Wes
Old 07-25-2001, 02:48 AM   #14
scorp508
CF Senior Member
scorp508's Avatar
Quote:
Originally Posted by westifer:
[B
Open Air Lid description[/B][/color]
Basically you cut the front of the lid off so that it exposes the air filter. Leave just a border around the edges to keep the air filter firmly in place, but remove the face of the lid. [img]http]//www.corvetteforum.cc/ubb/smile.gif[/img]
Old 07-25-2001, 03:55 AM   #15
65Z01
CF Senior Member
Cruise-In II Veteran
65Z01's Avatar
Send a message via AIM to 65Z01
$160-cold/ram air intake w/ K&N filter.
$ 90-HyperTech coil/cap/rotor.
$ 60-TPIS wires.
$ 0-Cut back spark plug ground electorde & gap to .045".
$ 15-160 deg stat.
$ 40-160 deg HyperTech aux fan sw.
$ 5-splice & spade lugs & wire (see my C4 tech description).
$ 0-gut the MAF.
$ 10-TB bypass parts.
$ 40-MAT relocation kit
$ 60-HyperTech AFPR.
$ 50-ACCEL fuel pressure gauge.
$ 0-Remove "frisbee" from water pump pulley.
$530-Total
These mods should net you about 30 HP or so, enough to feel nicely and keep you busy for a while.
Later whan you have $500-$1000 have a custom 2 1/2" front Y-pipe made up, install a Random Tech cat, install muffler elims or a TPIS Flow Master cat-back. These will get you another 30 HP or so.
If you lose the spare/jack/etc and carry a puncutre repair kit and cell phone you will be about 50 lbs lighter (similar to 5HP). Cruise with about 1/3-2/3 tank of fuel and you will be 70lbs lighter than a full tank (similar to 8HP).
I'm also sending you data on L98 mods.
65Z01 is offline   Reply With Quote
Reload this Page What is best $500 mod on L83 engine performance?
Tags
1984, c4, corvette, corvettes, define, engine, fixing, l83, mods, motor, performance, plugs, rpo, spark, upgrade
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
