REALLY basic torque converter question
Automatic transmissions have never been my strength and I know little (ok, almost nothing) about them.
So here goes - What is the significance of stall speed? When is higher/lower desirable?
Sorry - but I had to ask
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
"stall speed" is the engine rpm that the TC allows at full throttle starts.
A higher stall speed TC lets the engine rev higher at the start, putting it deeper into the power band. For an engine with all its power located up in the higher rpm range, this is a real advantage.
For stock motors, it just makes it feel like the transmission is slipping...IMHO.
Larry
Larry
Received 1,401 Likes
higher stall is desirable when your torque peak is at a higher rpm, close to the torque peak is where you want to be
For L98s the torque peak is low, so 2000-2200rpm is desirable, whereas the LT1s is up higher so for optimum 1/4mi times the stall needs to be 3000 or higher.
But for a street driven car the stall should be kept below about 2600 or it'll feel really weird.
Thanks - That makes sense - at least to me. Since I plan to keep my engine basically stock and am more into solo/auto-x type stuff than drags I guess I don't have to worry about the TC either. Good to know.
Cruise-In II Veteran
What year Vette do you have?? I think the early TC were around 2,000rpm and later ones about 1,500rpm.
I had a 2,000rpm installed in my '88 and it feels stock for normal driving but does launch a lot harder. I have a 3,000rpm TC in the IROC and didn't want one that "loose" for the Vette.
For auto X you might consider a TransGo shift kit with a manual valve body setup, if you don't mind doing your shifting manually on the street too.
