What is the best way to launch my car?
Old 07-21-2001, 05:43 PM
BlueC4 LT1
BlueC4 LT1's Avatar
OK, here's the deal, I have a 94 automatic (coupe) K&N w/ open lid, HPP, Dana 36 with 3.73's, Flowmaster cat back exhaust, and Nitto 555 drag radials. Keep in mind that I have a stock torque converter. Should I just put it in D, turn asr off and mash the gas pedal? Or should I bring the RPM's up a little by power braking before launching??? Can someone give me the best advice? Step by step woud be best
Old 07-21-2001, 06:16 PM
Chris@SD
Chris@SD's Avatar
Step by Step:
1. Roll around the water box.
2. Burn the tires until you see smoke in your rear view mirror and then cound at least another 3 seconds(you want to start in First and go to second).
3. Put in first gear.
4. do not rev the motor. The converter will flash higher if you do not pre-load it.
when the second amber lights up, hit the gas!!!
Merry Christmas and good luck,
Bat Man
Bat Man's Avatar
Power Brake till the car starts budging, hold it there, once the xmas lights go, mash it!
Old 07-21-2001, 07:24 PM
65Z01
65Z01's Avatar
Cruise-In II Veteran
I like to do a little dry burn out (streets), stage up and bring RPM up to about 800-900. That way I preload the drive train and still get a nice flash from the stock TC.
In my IROC with DRs I prefer to roll through the water box and realy smoke em up.
Try several launches wet and then dry to see what works best for you (plus it's fun to gen a big cloud, legally).
As a word of caution, with a Dana 36 and 3.73s you likely don't want a high stall TC. I've seen a 36 come apart from hard launches (1.7x 60' times) with a similar setup and a performance TC.
Old 07-21-2001, 07:41 PM
Mr Mojo
Elite Torch Red Member
Support Corvetteforum!
Mr Mojo's Avatar
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I'll agree with Jim on this one, you don't want to get the revs up too high. I've seen peopel do what Tay Jay described and all they get is left at the line because they are spinning.
Leave it in "D" or 3, not "OD". Let it shift itself(more consistent).
Old 07-21-2001, 08:27 PM
MinnesotaWhite
MinnesotaWhite's Avatar
[/color]
Mojo..."D"...no kidding? Who would have thought!
Old 07-21-2001, 09:01 PM
Mr Mojo
Mr Mojo's Avatar
Originally Posted by MinnesotaWhite:
[B
[/B][/color]
You'd be surprised [img]http]//www.corvetteforum.cc/ubb/smile.gif[/img]
Old 07-21-2001, 09:23 PM
mackeyred96
mackeyred96's Avatar
Location: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Originally Posted by Mr Mojo:
[B
[/B][/color]
Frank is correct on this one. This is of most repetitive question I get along with how to launch.
I done every way there is and I found it best to come off at a dead idle. Some guys (Panuzzo) like to take the slack out of the drive line and bring rev up a few notches, it a little easier on the rear, 1/2 shafts and drive shift but I found the best way is to floor it off a dead idle.
Old 07-21-2001, 09:46 PM
corvette dude
corvette dude's Avatar
how about a manual tran. Whats the best way to launch. Gettin the itch to go down to englishtown.
Old 07-21-2001, 09:48 PM
mackeyred96
Originally Posted by corvette dude
how about a manual tran. Whats the best way to launch. Gettin the itch to go down to englishtown.[/color]
Thats a hole new deal. Not as easy as a A4 AND NOT MANY CAN DO IT RIGHT.
To What is the best way to launch my car?
Quick Reply: What is the best way to launch my car?
