Max compression ratio on Sunoco 94?????
I have a 355 Chevy carburetted engine with cast iron Vortech heads. I'm looking for input as to the max compression ratio that I can run using Sunoco 94 pump fuel. I do not want to go to race fuel and this is in a C4 that is used for road racing. All input and guidance is appreciated.
Location: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
1 Post
I ran 11.8:1 with steel Sportsman IIs on my 406, but NEVER when I was at the track. You could mix with a 110 or 112 if you can find it.
Originally Posted by Nuvolari
This engine is totally old school. Carburetted with no computers.
I'd say 10.5 on the safe side but maybe a little more with a perfect tune. Vortech head have a good combustion chamber and a well placed plug so you can run a little more comp. than most heads. Also because of the good CC you don't need as much timing. 30 degrees is probably enough.
Originally Posted by scorp508
You can still get 94? They took it away from our pumps.
That is what I was thinking. It happened up north first, then about 2 weeks ago it disappeared in our area.
