pressure in oil tank
hi all maybe some one can help me. i am getting what i think is pressure in my oil tank because i am get oil coming out of my dip stick when i step on the gas so much pressure it pops the dip stick out of its seat.i need all the help i can get.
thanks.
thanks.
You may be getting an excessive amount of blow by due to ring failue. But that's just a guess. How long have you had the 383? When did this start happening? Are you burning any oil? the more info the better.
when i got it back from the shop.i had all the work done at onces,blower,intercooler,stroker LT1,R700 trans and full bora exhaust header back to mufflers.
You weren't reving the engine past 3K or so when you were breaking it in were you??? How many miles are on the engine? You need to give it a good 500 miles atleast of break in time for the rings, running regular oil, not synthetic. Also talking to the shop that did the work would also help. I'm assuming that they will stand behind their work, atleast a little.
My engine builder said break it in the way you going to drive it .......drive it hard if you like just DON'T GET IT HOT.....blow by is part of supercharging the more boost the more blow by, even with a newer engine you just have to deal with it by venting the engine or with high boost, with a vac pump.
My guess is not blow by, but a blown head gasket. Sounds like its blown between a cylinder and a oil passage. Happen once on my GN and it had the same symptoms.
Good luck.
Good luck.
