installing ford injectors will the fit (how to)
Old 09-16-2004, 11:02 AM
90corvette
90corvette's Avatar
Default installing ford injectors will the fit (how to)
any ideas on how they fit i understand they are a little short
how do you solve that problem
Old 09-16-2004, 09:21 PM
kenv
kenv's Avatar
Location: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
I just installed the 22# Ford take offs from 5.0 Motorsports ( $98.00 for a set of eight ) in my `87. these are brand new take offs. They have the " pink " tops. They work great for me.
Ken
Ps: they are the same size as the originals, so no fitment problems. They even came with the "O" rings attached.
Old 09-17-2004, 12:20 AM
skateparkdave
skateparkdave's Avatar
St. Jude Donor '05-'06
Most brands are a tad shorter than originals. No worries, will work fine. Just rub on a lil' smidge of lube (Not much, I used a very small rub of white grease) around O rings and pop them in.
To installing ford injectors will the fit (how to)
Quick Reply: installing ford injectors will the fit (how to)
