PKE System woes
Cruising
PKE System woes
I recently had the CCM computer replaced in my 93 LT1 - a repair shop fried it while changing the heater core.
The PKE system unlocks the doors fine but when you move the key fob away, it takes 15 seconds for the doors to lock, not the usual 3 to 4 seconds. Also, when turning the system on or off (by holding down the door button on the fob) it recognizes the fob command right away, but takes 15 seconds to cycle the locks.
Does antone else know what's wrong?
The shop, a corvette speciality shop, is stumped, has contacted GM and if no luck, is about to contact Gordon Killebrew.
