Sea Foam, wasted money or does it work
Old 10-05-2004, 02:37 AM
jzvette
jzvette's Avatar
Default Sea Foam, wasted money or does it work
I hear people talk about using Sea Foam, does it really do what it claims to (Which is like almost everything).
Old 10-05-2004, 02:53 AM
black_89_vette
black_89_vette's Avatar
I used a product called Cleens. It used to be called GM Top Engine Cleaner. It seemed to help idle quality afterwards and on a scan run with DataMaster, it dropped my IAC counts from mid 60's to like 32.
Old 10-05-2004, 04:52 AM
comp
comp's Avatar
used for years but nothing is a fix all
Old 10-05-2004, 10:12 AM
rick lambert
rick lambert's Avatar
It has always worked for me-no disappointment here
Old 10-05-2004, 10:33 AM
GKK
GKK's Avatar
I used it on my "89" Vette a few months ago (L98 74K miles). I followed the instructions on the can to the letter and after letting the Seafoam soak in the engine for 10 minutes, I started it up expecting to see clouds of smoke.
I was surprised to only see a very tiny light puff of smoke. So, I thought to myself the engine is either really clean or the Seafoam doesn't work.
I also cleaned the Throttle Body and Plenum with some Amsoil foam throttle body spray but, found that the throttle body was already clean and the foam spray really didn't do anything.
Old 10-05-2004, 10:44 AM
HammerDown
HammerDown's Avatar
Which vacuum line did you pour the Sea Foam in?
Old 10-05-2004, 12:33 PM
Rich & Lisa_84
Rich & Lisa_84's Avatar
Location: I live at www.domesticlugnuts.com I sleep in PA
My Neon which I drove 4 times last year, kept getting all 4 injectors clogged from a major amount of dirt in the tank. ( My EX...I think) Anyhow, I kept cleaning the injectors and it would only run for about 20 minutes before it would start acting up again. I added a can of Sea Foam to the tank and it has ran for about 1000 miles so far without any problems. I added a can to My Vette to clean out the carb. So far so good. I recommend using it.
Old 10-05-2004, 02:05 PM
GKK
GKK's Avatar
I used the brake booster vacuum line and the pcv line.
Old 10-05-2004, 02:08 PM
bogus
bogus's Avatar
I used this stuff yesterday, infact.
My observations match yours! A small puff of smoke, from just the right bank! I have seen video of a huge cloud - forum member video!
I guess we just use good gas!
I did notice that it ran smoother and seemed a bit more responsive.
Old 10-05-2004, 02:24 PM
HammerDown
HammerDown's Avatar
I think I'm going to try this. Couldn't hurt, and it will just eliminate one more possible cause of my high rpm vibration.
Old 10-05-2004, 06:23 PM
Wayne88
Wayne88's Avatar
Try to find it.
I gave up.
I tried Pep Boys, Auto Zone. Ecklers, and a bunch of other stores.
I never saw it anywhere.
Old 10-05-2004, 07:05 PM
GKK
GKK's Avatar
Napa carries Seafoam and I just saw it in an Autozone which never carried it before.
Old 10-05-2004, 09:25 PM
1987C4
1987C4's Avatar
I saw it at Advance Auto Parts as well.
Brad
Old 10-05-2004, 09:38 PM
jzvette
jzvette's Avatar
thanks for all the info, I will try it and see.
Old 10-05-2004, 09:48 PM
jzvette
jzvette's Avatar
How do you get to be an elite member with all the colored stars.
Old 10-05-2004, 10:14 PM
CF6873
CF6873's Avatar
Be careful pouring liquid into the brake booster line. If too much goes in too fast you can hydro lock the motor and bend rods. As for Seafoam I think it's a great product. Craig
Old 10-05-2004, 11:25 PM
kenv
kenv's Avatar
Location: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Originally Posted by Wayne88
Try to find it.
I gave up.
In my neighborhood, the local NAPA sells it. Personaly, I heard some bad comments about that stuff when I used to be on the Z28.com forum boards. That was about a year ago, mabey things have changed. I don`t stick any of those " wonder " chemicals in my engine. If it ain`t broke, don`t fix it.
To Sea Foam, wasted money or does it work
Old 10-06-2004, 10:31 AM
VR'92
VR'92's Avatar
Location: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
You gotta make about 10,000 posts Get started
Old 10-06-2004, 10:39 AM
rick lambert
Like I said I've used it for years on several cars-the only thing I do different is I don't put it in the crank case-1/2 in fuel tank, 1/2 thru vacumn. Works for me.
Old 10-06-2004, 10:59 AM
onedef92
onedef92's Avatar
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I've never tried Sea-Foam so I can't say. What I do, though, is add one quart of ATF to a full tank of gas every 3,000 miles after an oil change.
It's safe for your injectors and O2 sensors and won't harm your emissions equipment, either. Ever see the guts of an auto tranny?
Well, the detergent package in ATF cleans intake valves and injectors like nobody's business when mixed with gasoline. It's an old mechanic's trick.
Quick Reply: Sea Foam, wasted money or does it work
