Old 02-20-2015, 01:54 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
[L98] How Hard Is It To Replace The O2 Sensor?
Old 08-21-2004, 05:03 PM
j3studio
Support Corvetteforum!
j3studio's Avatar
Cruise-In V Veteran
St. Jude Donor '06
Default [L98] How Hard Is It To Replace The O2 Sensor?
Folks,
How hard is it to replace the O2 sensor on an L98? Do I really need to "elevate" like the service manual says?
Getting in deeper and deeper...
Old 08-21-2004, 05:22 PM
CFI-EFI
CFI-EFI's Avatar
I can reach mine from the top or the bottom. You may have to go underneath to disconnect the pigtail from it's connector. After that, put a 7/8ths" box or open ended wrench on it and turn counterclockwise. To reinstall, reverse the process. If it is not a NEW sensor, you're installing, put a little anti seize on the threads, only. It's easier than changing to oil.
RACE ON!!!
Old 08-21-2004, 06:40 PM
SupaVette
SupaVette's Avatar
RACE ON!!!
Old 08-21-2004, 11:23 PM
1987C4
1987C4's Avatar
Just did mine. Piece of cake. I have a lift, so I had it easy. As noted, disconnect electrical lead, unscrew and replace. I did notice a slight increase in throttle response and a slight improvement in the idle.
Brad
Old 08-24-2004, 01:45 PM
grapidssteve
grapidssteve's Avatar
when I did mine on an '85, it was suggested to me to 'warm' the car up a little to help with the removal of the old one. It was a long time ago, but I think I ran the car for about 1 minute. You don't want the exhaust pipe hot, that's for sure.
Old 08-24-2004, 02:40 PM
j3studio
j3studio's Avatar
Cruise-In V Veteran
St. Jude Donor '06
Thanks, everybody!
Old 08-24-2004, 02:45 PM
j3studio
j3studio's Avatar
Cruise-In V Veteran
St. Jude Donor '06
Thanks, everybody!
To [L98] How Hard Is It To Replace The O2 Sensor?
Quick Reply: [L98] How Hard Is It To Replace The O2 Sensor?
