Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-17-2004, 05:34 PM   #1
j3studio
CF Senior Member
Cruise-In V Veteran
St. Jude Donor '06
Support Corvetteforum!
j3studio's Avatar
Default [85 LCD] The Dreaded Intermittent Electrical Problem
Sometimes, either when I've just started up or I've been driving for a couple of minutes, the LCD display on my 1985 will go completely blank. Everything else (at least everything else I've had the presence of mind to check while this is happening) keeps working fine. Sometimes the LCD display will give the impression that something is going on, but most of the time it is completely blank.
A couple of restarts later, the LCD display will magically start working again.
I looked in the 1985 service manual (I'm learning ) and the #1 troubleshooting hint for the instrument cluster is to check the LCD fuse, the CLSR fuse, and the G201 ground.
Some questions:
1) I'm assuming that it can't be the fuses since the LCD display works most of the time. Is that correct?
2) The G201 ground is said to be behind the instrument panel and near the left hand side of the steering column. I looked through the entire electrical diagnosis portion of the service manual and I can't for the life of me find a diagram that shows the location [there are diagrams that show G100, G101, G103, G104, G115, G116, G125, G140, G320, G400, and G401 ]. Is G201 hard to get to?
3) Am I missing something really obvious?
j3studio is offline   Reply With Quote
Old 08-17-2004, 06:38 PM   #2
SupaVette
CF Senior Member
SupaVette's Avatar
Send a message via AIM to SupaVette
I would check the fuse anyway, quick and easy. Maybe you should try checking the connectors on the display itself. this is not such a great job as you have to remove the whole display cluster. It has 2 connectors on the left at the back
SupaVette is offline   Reply With Quote
Old 08-17-2004, 06:49 PM   #3
j3studio
CF Senior Member
Cruise-In V Veteran
St. Jude Donor '06
j3studio's Avatar
Thanks, Peter!
Old 08-17-2004, 10:51 PM   #4
mikey whipreck
CF Senior Member
mikey whipreck's Avatar
Hey I've got an 85 that has the exact same symptons you describe... only problem is, about 3 or 4 days ago, it went black, and hasn't come back since... Maybe we could help each other on this... I've tried a ton of stuff trying to fix it... i haven't heard of the ground near the steering column though. I've checked (and cleaned) 3 other grounds related to this, and it hasn't helped. Have you search for this ground yet?
mikey whipreck is offline   Reply With Quote
Old 08-17-2004, 10:56 PM   #5
mikey whipreck
CF Senior Member
Oh yeah- i just bought gordon killibrews' book on the digital dash. I was told it was excellent... do you have it?
Old 08-17-2004, 11:54 PM   #6
bogus
CF Senior Member
Send a message via Yahoo to bogus
this sounds a lot like the ground problem... I would focus on that.
bogus is offline   Reply With Quote
Old 08-17-2004, 11:55 PM   #7
mikey whipreck
CF Senior Member
Yeah, but where is that ground in the steering column? I had never heard of that before
Old 08-17-2004, 11:59 PM   #8
bogus
CF Senior Member
ah... that could be interesting... on TOP of the steering column, there are a multitude of wires connecting to the ignition system, signals and such. you may have to drop the column from the dash to reach them ok. A corroded connection could cause this problem.
Old 08-18-2004, 12:12 AM   #9
steveb
CF Senior Member
steveb's Avatar
Send a message via ICQ to steveb
I agree that it sounds like a ground problem. This site has some good information on the digi dash. www.batee.com/corvette/index.shtml
steveb is offline   Reply With Quote
Old 08-18-2004, 12:27 AM   #10
mikey whipreck
CF Senior Member
Quote:
yeah that sites good, and i've been all over it- but it makes no mention of this steering column ground... I've had some funky stuff happen to the dash while messing with levers on the column. I think you guys may be onto something...
Hey j3studio, have you tried anything yet to solve your problem? I'm interested to see if you've done anything i haven't
Old 08-18-2004, 12:30 AM   #11
SunCr
CF Senior Member
G201 should be on the left kick panel. Remove the hush panel and then find the black support bar. It's either on it or next to it.
Doubt that's your problem though. This ground is spliced to a host of other stuff, so if everything else is working ok, this ground is probably good.
The other ground could be your problem. It runs to the ambient temperature overide switch and then out through the big connector behind the battery to the trans (upper left bolt for your year). As Killebrew points out, that connector can collect water in the base, where the ground passes through, corroding the contacts. His solution is to solder the grounds at the display - pins D1 & D3.
If you're going to remove the connector, take out the battery first. The upper half is the light circuits - all the engine stuff is in the bottom. Cleaning it can be a chore and some electrical cleaner that won't harm the plastic works pretty well. Smear dielectric all over everything and then Killebrew recommends that you spray it with undercoating after it's back together. Do make sure that the fresh air plenum drain tube is pointing away from it and the fusible links behind the battery.
SunCr is offline   Reply With Quote
Old 08-18-2004, 12:38 AM   #12
mikey whipreck
CF Senior Member
Quote:
fixed that ground (overide it), didn't help. Grounds in the display were soldered when i sent it away to get fixed. no dice
Old 08-18-2004, 03:08 AM   #13
yellowlust
CF Senior Member
yellowlust's Avatar
Click the image to open in full size.
This right here did it for me. Once I soldered this extra ground on my 86 all my worries went away.
$200? Nope. Just replaced the bulbs and added one piece of wire.
Here's the page.
It might look complicated to some but it was relatively easy. Just keep unscrewing the IP until you get to the good stuff. I got so good I could get the IP out in my sleep. (Kept taking it out until I found out how to fix it, finally).
Nothing feels better than after putting up with an intermittent dash to know that it'll never flicker again.
yellowlust is offline   Reply With Quote
Old 08-18-2004, 09:31 AM   #14
mikey whipreck
CF Senior Member
Here's the page.
That looks good, and if j3studio hasnt tried it yet he definitely should. But I seem to be having the same symptons his dash has, and I HAVE done that... and it didn't help
Old 08-18-2004, 11:41 AM   #15
Toymans85
CF Senior Member
Toymans85's Avatar
I too had this problem in both 85's
I added the soldered wire like above and it worked great after.
Good luck
Toymans85 is offline   Reply With Quote
Old 08-18-2004, 03:13 PM   #16
yellowlust
CF Senior Member
yellowlust's Avatar
Quote:
Have you also addressed the ambient temperature switch ground?
Old 08-18-2004, 03:18 PM   #17
j3studio
CF Senior Member
Cruise-In V Veteran
St. Jude Donor '06
j3studio's Avatar
Default Re: The Dreaded Intermittent Electrical Problem
Mikey,
I haven't gotten to this yet - the engine is throwing codes again , so that's my biggest priority right now. I don't have Gordon's digital dash book, though that's probably going to be a Carlisle pick-up.
Old 08-18-2004, 03:20 PM   #18
j3studio
CF Senior Member
Cruise-In V Veteran
St. Jude Donor '06
j3studio's Avatar
Great stuff, everybody! Thanks a lot!
Old 08-18-2004, 09:00 PM   #19
mikey whipreck
CF Senior Member
Yeah i have... that was the first thing i tried... This has been driving me crazy... Thanks for the input guys... I ordered Killebrew's book a few days ago, and i'll try it again when I get it... I also plan on being at Carlisle, maybe i can get some more input from people that have been through digital dash hell
Reload this Page [85 LCD] The Dreaded Intermittent Electrical Problem
Tags
85, 885976, c1, c4, cluster, corvette, diagnosis, digital, display, electrical, g140, g201, ground, grounds, intermittent, lcd, temperature, working
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
