Fuel Pump Relay Location in 1990?
Hi,
I've been trying to find the fuel pump relay since yesterday and I think I've narrowed it down to the area located to the left of the steering column under the instrument panel. According to a Hayes C4 book, I believe I found the turn signal flasher (a circular unit with strips of yellow tape) and assumed the relay to be nearby. Now, next to it are two relays. I looked at both and they are identical (at least according to the wiring schematic on the actual relay).
Does anyone know which relay is the fuel pump relay in relative location to the turn signal flasher? Is it the one closer to the turn signal flasher (with tan wires) or the one further away (with brown wires)?
Here's a medium size pic (~400KB)
Larger pic (~700KB)
Thanks for any help,
Ryan
Info about the car:
1990 non-ZR1 (L98) with 32k miles.
Larger pic (~700KB)
Ryan
Info about the car:
My GM shop manual is a bit confusing. It shows fuel pump relay #1 below the passenger side dash and refers only to that location in the index of component location. I know it's there because I have been up there working on the horn relay near it. The manual also shows a component diagram with fuel pump relay #2 where you are now. It is the left one looking forward. The circuit diagram for L-98 shows only one relay in the circuit. Further inspection of the LT-5 circuit shows the second fuel pump. Look under the passenger side for yours. It is the middle of the five relays. If you need one, I have a new spare I don't need. Just verify the part number to me.
Lou
Lou
St. Jude Donor '05-'06
that the GM manual is a bit confusing on this. Mine for 1990 shows it to be in a relay bank below right hand side of IP and it shows 5 relays. Two from one wire harness and three from another wire harness. From left to right if your in seat facing forward and the fuel pump relay #1 is first on left. Its one of the three grouped from one harness. Then the horn relay, then rear defog relay.... Then fog lamp relay, then dome lamp relay at far right are grouped together in that order from the other wire harness. Hope this helps.
Ah. Thanks guys! You both gave a clear description of where it's located. Too bad I went through the wrong route. But at least it was a learning opportunity.
Anyhow, tonight, I'm going to open up the passenger side area and find the FP relay.
Arrest Me Red, thanks for the offer on the relay, but I already bought one from Autozone. I think the GM part number is 25520198 according to a previous thread. Unfortunately, there's no way to map it to an Autozone item number. Thanks for the offer nonetheless.
To both, thanks for the clarification.
Ryan
Ryan
Originally Posted by REW89
On my 89 the fuel pump relay is located on the firewall, between the brake master cylinder and the engine.
Maybe it is different for a 90.........
Bob
Bob
But thanks for your input.
Bob
Bob
