Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-08-2004, 11:52 PM   #1
jr20516v
Junior Member
Default would bad brake fluid cause the ABS light to come on?
My LTI [1993] ASR and ABS lights [and sometimes a flashing red brake light on the dash ] keep coming on after mild braking. I seem to have only 50% braking.
I have checked brake fluid level [good ] and also brake pads...also good
however on looking at the color of the brake fluid it is a browny/black and may be the cause of my problems. If the fluid is old or very dirty it may block up the ABS sensors and create the light to come on.
Has anybody had similar problems or point me in the right direction??
Cheers for any help !! John
jr20516v is offline   Reply With Quote
Old 08-09-2004, 01:13 AM   #2
jabez
CF Senior Member
jabez's Avatar
Send a message via ICQ to jabez Send a message via AIM to jabez
You can short Pins A and G on your ALDL and see if any codes pop up on your dash under module 7.
jabez is offline   Reply With Quote
Old 08-09-2004, 02:24 AM   #3
aklim
CF Senior Member
aklim's Avatar
Send a message via Yahoo to aklim
When my alternator was shot the low current left in the battery caused it to come on too. Not saying that is your problem but make sure you have ample battery power from the alternator and battery.
aklim is offline   Reply With Quote
Old 08-09-2004, 08:20 AM   #4
runner140*
CF Senior Member
Support Corvetteforum!
runner140*'s Avatar
Default Bad brake fluid
The first thing you should do if your brake fluid is brownish, is to flush it
and replace it with a synthetic. Its a cheap fix. Problem is that a large
percentage of your brake fluid is now boiled brake fluid and water.
runner140* is offline   Reply With Quote
Old 08-09-2004, 08:29 AM   #5
STEVEN13
CF Senior Member
STEVEN13's Avatar
I would say to also change the brake fluid. I know you said the fluid was full however, on my 1992 once at the track under hard braking both the ABS and ASR came on at the same time. Cause: the fluid was just a little low.
Good luck,
Steven
STEVEN13 is offline   Reply With Quote
Old 08-09-2004, 12:12 PM   #6
SilverBeast
CF Senior Member
St. Jude Donor '05
SilverBeast's Avatar
I'd flush and change with brake fluid that color anyway. It may or may not solve the problem, but it'll brake better.
SilverBeast is offline   Reply With Quote
Old 08-10-2004, 08:23 AM   #7
jr20516v
Junior Member
Thanx for all those helpful replies. It is now fixed and i am as happy as a dog with 6 tails !!
I replaced the fluid and cleaned all sensors...some had iron filings on them which would not have helped. Reset the code "low fluid" and Presto !! No more lights and great brakes again.
cheers again.
Reload this Page would bad brake fluid cause the ABS light to come on?
Tags
abd, abs, bad, black, brake, c4, causing, corvette, dirty, empty, fluid, light, low, make, on
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 Tech 252 02-02-2014 12:23 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
