who hates their stock brakes?
im driving down a nice semi windey road, get in a few corners pretty hard, start to smell the brake heat up, nothing unusual. get to the next corner and push the brakes hard as a rock and not slowing down. now i have a good set of brake pads on and a decent set of aftermarket rotors. i had a 90 vette before this a i had the 13" brakes on it and i never had a problem stopping when i drove them hard.
my question beside how stoned the engineers were when they designed they brakes is what can i do (without spending 3k) to improve my brakes so i dont kill myself.
I had a similar experience with mine, they would heat up and quit working right. I changed the brake fluid ( to remove moisture) and switched the front rotors over to slotted/cross drilled Brembo's and the heat/problem was corrected. My biggest problem was high brake temps were boiling the fluid. If you never replaced the brake fluid, try that first. Then look at your brake booster, it may be getting tired. I hope this helps.
Oh yeah, the brakes on Corvettes are typically very good when working properly.
Received 1,400 Likes
I'm not particularly fond of them, no.
In about 2-3mos, I should be able to do C5 Brakes.
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Brake fluid can be a problem if it is old or has been heated consistently. Look at the reservoirs, if the fluid is gray or worse, it needs to be changed.
The system is assuming you already have the 13" front rotors so that would be an extra expense for you. I am not sure if anything more would have to be done because you have a 91.
1 Post
Cruise-In I Veteran
Cruise-In V Veteran
If you already have 17" A Mold or C5 wheels, you can do a conversion to C5 brakes for less than $600.00
Ed Salinas, a member here has the adapters, C5 roters and calipers are around $ 200 per wheel and then the pads are your choice.
I got my C5 stuff in C5 parts for sale for less than $ 75 per wheel
You don't need to convert the rears since there is no substantial difference between C5 and C4 rear brakes
Installing the DRM proportioning spring will also add to your enjoyment
Jack
Jack
Originally Posted by jackdaroofer
If you already have 17" A Mold or C5 wheels, you can do a conversion to C5 brakes for less than $600.00Jack
Sounds like a good excuss to buy a new set of rims
Location: Looks like I picked the wrong week to stop sniffin glue Orlando
I found the whole C5 conversion on Ebay for 350.00 The deals are out there you just have to keep looking
http://forums.corvetteforum.com/showthread.php?t=845330
Originally Posted by Nathan Plemons
you guys have got to keep it in perspective as well. Name a car of your 19xx year that has brakes as good as your vette.
Originally Posted by IBEAM700
I found the whole C5 conversion on Ebay for 350.00 The deals are out there you just have to keep looking [/URL]
Does the seller have more?
Originally Posted by corvette-pilot
Do you have the link to the ebay ones? would be nice to see what is included.
My Dad's '77 stock radio doesn't pickup XM Satilite radio channels, what the hell was GM thinking??
Location: What did the 5 fingers say to the face? SLAP!!
They definitely don't work worth a crap if you only have 14" of manifold vacuum. Early C4 rotors are also very susceptible to warping. Even in stock form, I think that's unacceptable.
