Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-04-2004, 07:40 PM   #1
Sunyi
CF Senior Member
Sunyi's Avatar
Send a message via AIM to Sunyi
Default New 383 engine, spun rod bearing
Recently, I had my 383 engine built by a machine shop based on a rotating assembly from Eagle
Went to the track this friday and on the end of the first pass, the engine started to make knocking sound.
Pulled the pan and found a spun bearing on the third journal from the front of the engine. The engine only has 140 miles on it and this is the second time i have to pull it.
The first time was because the same machine shop did a terrible job mounting the core plugs, the rear left one simply poped out during the camshaft break in:shocked:
I strongly belive that they did not check the bearing clearences, and just simply slaped the engine together.
What do you guys think that could have caused this faliure.
I now that I did not loose any oilpressure because I monitored the oil pressure guage during the whole run.
This is what it looks like:
Click the image to open in full size.
[Modified by Sunyi, 9:58 AM 7/7/2004]
Sunyi is offline   Reply With Quote
Old 07-04-2004, 07:46 PM   #2
Corvette0096
CF Senior Member
Corvette0096's Avatar
Send a message via Yahoo to Corvette0096
Default Re: New 383 engine, spun rod bearing (Sunyi)
Oil starved or the bearing where set up wrong or touqed down wrong.
Corvette0096 is offline   Reply With Quote
Old 07-04-2004, 07:50 PM   #3
FD2BLK
CF Senior Member
FD2BLK's Avatar
There are several reasons it could have hapened but most point to the motor assy. Improper cleaning would be a posibility that I would think of first. If you had a new rotating assy then I doubt it was a clearance problem. If they installed the cam bearings wrong then that could also cause a oil starve situation. I hate to say this and I know you probably already know but the whole thing needs to be torn down and cleaned before re-assy.
[Modified by FD2BLK, 6:51 PM 7/4/2004]
FD2BLK is offline   Reply With Quote
Old 07-04-2004, 07:53 PM   #4
Sunyi
CF Senior Member
Sunyi's Avatar
Default Re: New 383 engine, spun rod bearing (Corvette0096)
I do not think its oil starvation, the oilpressure did not drop during the run.
The rest of the bearings look just fine. Shouldent they also be badly damaged by starvation
The fact that the shop did a so so job with the core plugs tell me that the rest of the engine was done in the same manner.
[Modified by Sunyi, 1:58 AM 7/5/2004]
Old 07-04-2004, 08:02 PM   #5
Sunyi
CF Senior Member
Sunyi's Avatar
How can the cam bearings affect the oilflow to the main/rod bearings?
Old 07-04-2004, 08:33 PM   #6
tjwong
CF Senior Member
Support Corvetteforum!
tjwong's Avatar
Send a message via AIM to tjwong
The cam bearings are fed by the main bearings so even if the cam bearings we done wrong they would have went away long before the rod bearing. And there would have been problems before going 140 miles. I would be will to think that it was improper clearances, or contamination that caused the failure. What did the other bearings look like? You mentioned it was the third journal so that means it with either number 5 or 6. Which is close to the rear main cap. What did number 1 look like? If that one is wasted as well, it would be a sign of oil starvation as it is the furthest crank throw from the pump.
tjwong is offline   Reply With Quote
Old 07-04-2004, 10:53 PM   #7
Sunyi
CF Senior Member
Sunyi's Avatar
Default Re: New 383 engine, spun rod bearing (tjwong)
The bearing spun on cyl no. 3 (second on the driver side, from the front ), The Cylinder no. 1 bearing looks just as fine as the rest of the bearings.
[Modified by Sunyi, 4:54 AM 7/5/2004]
Old 07-04-2004, 11:38 PM   #8
FD2BLK
CF Senior Member
FD2BLK's Avatar
Let me clarify "wrong", what I am saying is if they got any contaminants into the oil galleys while they where installing the cam bearings or cam then it can cause starvation problems. I have seen several problems with people posting a spun rod bearing after a cam install particularly with the LT1s. I still would be surprised if you had a clearance problem with a new crank and rods. I always check clearances on every motor I build and while I have only built 12 motors I have yet to see a problem with a set of bearings being out of spec. I did have a situation on one motor where the clearances where a little on the loose side but it was still with in spec.
Old 07-04-2004, 11:45 PM   #9
tjwong
CF Senior Member
tjwong's Avatar
Default Re: New 383 engine, spun rod bearing (FD2BLK)
Contaminants, foreign material is the number one cause of bearing failure in engines or industrial bearing situations.
Old 07-05-2004, 08:29 AM   #10
silver84
CF Senior Member
silver84's Avatar
That picture is of a main bearing cap, or what?
How are main / rod bearings keep from spinning,
a mounting peg-hole, or just crush force, or whatever.
Sorry for bozo questions.
silver84 is offline   Reply With Quote
Old 07-05-2004, 10:13 AM   #11
rick lambert
CF Senior Member
rick lambert's Avatar
Default Re: New 383 engine, spun rod bearing (silver84)
I feel your pain. Happened to me once-and once is one time to many. I suspect a bad rod journal. Usually contaminats will affect the bearing surface-but aren't normally the cause for a spun bearing. The other thing would be improper torque. Then again I usually put on a few more miles and changed the oil before putting the hammer down.
rick lambert is offline   Reply With Quote
Old 07-05-2004, 08:07 PM   #12
Sunyi
CF Senior Member
Sunyi's Avatar
It is a picture of the rod cap.
The bearings are secured by a mounting peg-hole combined with crush force.
Old 07-06-2004, 08:26 AM   #13
0ski_dwn_it
CF Senior Member
ski_dwn_it's Avatar
Good oil pressure doesn't mean good oil flow. Something people VERY often misunderstand.
If you have a bearing too tight, it will increase your pressure. Since pressure is just a reading of restriction.
Oil volume is a whole nother game. You can have very high pressure, and not any oil volume. And visa versa.
Also all too often people think a good machine shop can build a good motor. Most of the time these guys know how to machine a block, but can't put one together.
In this case with the freeze plugs, I would say they can do neither. I would get your money back and take it to a well known engine builder and have them do it after they check EVERYTHING.
Sorry to hear about your troubles.
ski_dwn_it is offline   Reply With Quote
Old 07-06-2004, 10:12 AM   #14
Sunyi
CF Senior Member
Sunyi's Avatar
Default Re: New 383 engine, spun rod bearing (ski_dwn_it)
I picked this particular machine shop because they do all the engine work including the assembly for the Swedish supercarmanufacturer called Koenigsegg. Took it for granted thar they knew what they were doing
The ting is that it was this new young guy in the company that did the assembly work on my engine.
When it was time for the pistons (hypereutectic) to be mounted, they called me and said that i got the wrong rings for my 0.030 hypereutectic pistons from Eagle, that the ring gap was to large
When I left the motor at the shop, I gave them the ring gap chart that i got from Eagle. It clearly stated that the ring gap should be no less than 0.0060" in a N/A street engine.
It was the right rings they had, but they wanted to install them with a 0.0025 gap and the rings were gaped to 0.0050". That is why they called me to say that i should order a new set of rings :shocked: :shocked:
I bet they also torqued the caps wrong as well :mad
By the way, what is the right torque setting for the rod caps? (Eagle I-beam rods whith ARP studs)
[Modified by Sunyi, 4:15 PM 7/6/2004]
Old 07-06-2004, 04:26 PM   #15
Bruthish
CF Senior Member
St. Jude Donor '03-'04-'06-'08-'09
Bruthish's Avatar
Send a message via AIM to Bruthish
Please excuse my ignorance on this subject...but if it had only 140 miles on the motor, shouldn't there be a "break-in" period before doing hard runs like that? Just curious....
Bruthish is offline   Reply With Quote
Old 07-06-2004, 04:54 PM   #16
jefft84
CF Senior Member
jefft84's Avatar
my vote is the rod is on backwards. If the rod/piston is in backwards the bearing will get crushed when torqued down causing premature failure. Could happen in 50 miles could happen in 500 miles depends how tough the bearing is. check the side of your rod for any scuffs from rubbing the crank or adjoining rod, that would indicate severe side load and explain it. This problem will not show up as an oil pressure loss at all.
jefft84 is offline   Reply With Quote
Old 07-07-2004, 03:11 AM   #17
Sunyi
CF Senior Member
Sunyi's Avatar
Default Re: New 383 engine, spun rod bearing (Bruthish)
The shop claimed that the engine could take full load after the initial camshaft break in because of the special cylinder henning process
Very well, I thought. It is their butt if it breaks.
[Modified by Sunyi, 9:12 AM 7/7/2004]
Old 07-07-2004, 03:35 AM   #18
Sunyi
CF Senior Member
Sunyi's Avatar
Default Re: New 383 engine, spun rod bearing (jefft84)
I have studied the rod cap and found that the metal is blue on the sides. I have also found traces of wear on the sides but when i took it of the rod, it was is in the same position as the other 7 rods.
Click the image to open in full size.Click the image to open in full size.
[Modified by Sunyi, 9:38 AM 7/7/2004]
Old 07-07-2004, 01:19 PM   #19
jburnett
CF Senior Member
jburnett's Avatar
Send a message via AIM to jburnett
I'm going to go with improper bearing setup... Did they mic the rod bores with and without the bearings? Did they torque the bolts or stretch them... Did the load and unload the bolts two or three times before they checked the clearances? And another important question: these are new rods, correct? New rods will shrink .0005" or a little more once they're run which if they're improperly set up (ie., too tight) they will certainly cause that problem.
To this day I am shocked at the machine shops who profess to be "performance machine shops" that are everything but...
-Jeb
jburnett is offline   Reply With Quote
Old 07-07-2004, 01:39 PM   #20
devilfish
CF Senior Member
devilfish's Avatar
Default Re: New 383 engine, spun rod bearing (jburnett)
damn! I never heard of that Good point
devilfish is offline   Reply With Quote
Reload this Page New 383 engine, spun rod bearing
Tags
383, bearing, bearings, clearances, engine, hemi, main, rod, spun
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
383 build ? myvettesblue C4 General Discussion 28 06-12-2005 10:57 PM
After 11 brutal months the 383 (now 385) is now running luvmy92 C4 Tech/Performance 29 12-21-2004 03:09 PM
had a bad night ToyC4 C4 Tech/Performance 23 12-08-2004 01:19 AM
Main bearing tolerances (linehoning) Sunyi C4 Tech/Performance 12 08-02-2004 07:24 PM
Need Engine Advice for LT1/LT4 Rebuild ToyC4 C4 Tech/Performance 27 07-29-2004 09:03 AM
Spun Bearing question? XTRME 94 C4 Tech/Performance 13 11-29-2001 06:27 PM
my 383 experience mikey C4 Tech/Performance 11 09-05-2001 06:48 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
