Horn won't blow
Re: Horn won't blow (ringleader90)
my horn sounds like the last noise a dying old emphysemic goose would make on its death bed. it is actually fairly embarassing to use it...
Cruise-In II Veteran
Set the security alarm with the window down; reach in and unlock the door and open it. If the alarm sounds the horns check the horn ring.
If the horns don't sound, tap a jumper to the power connection of each horn; if they shound check the horn relay behind the center of the I/P in the mulit-use center.
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
:lurk: This can't stay serious for too long....
[Modified by JrRifleCoach, 1:35 PM 5/26/2004]
I had a case where the bayonet connector was not making perfect contact, and my horns didn't work only when the wheel was straight. Strange. (The connector is a spring loaded connector on the horn switch harness.)
Here's the post that describes this in a bit more detail.
http://forums.corvetteforum.com/zerothread?id=785963
:cheers:
:cheers:
Re: Horn won't blow (tempest)
:smash: There is a wire that goes into the steering column with a spring on the end of it that goes into a cam that is made out of plastic. The sping is always under tension and the cam broke. Had to pull the air bag and steering wheel to replace the cam.
