86 air pump elimination
Bringing it back from the dead.
When we eliminate the vac lines & EGR. Where do you tap the vac for the FPR? Also the cruise control.
Now that I have the intake off. I have acess to everything & would like to do this now. I already have the Air pump off along with the cluster of crap by the AC compressor. I have to figure out all the vac lines now. SO if I can just run what is nessessary it would be ALOT less work.
