garage door opener not working
6th Gear
My remote garage door opener dosen't work when I'm in my vette. Could it be the transmitter for my remote on the car crossing up the signal from the opener? The opener works fine when I'm in all my other vehicles.
Re: garage door opener not working (94polomike)
Does it make a difference if the car is running or not???
I had a car in the past that used to cause RF interferrence to garage doors and car alarms if it was running... It had a faulty alternator and stopped doing it a couple years later when the alternator was replaced...
6th Gear
I left polo out one night. I didn't sleep. the key pad out side the door and the remote will not work until I turn off the car.
6th Gear
Re: garage door opener not working (wake)
I guess l will be turning the car off to get in to my garage until my alternater stops chargering. Is that the only thing you changed when your opener stared to work again?
I have gone through two garage door openers but never had a problem with
it working with the engine on. Try to change the frequency on the opener
and on the motor. :rolleyes:
Re: garage door opener not working (elefkow)
easier to change the frequency on the opener. To properly change the frequency on the motor requires a new cam!! :jester :seeya
I've only seen this problem on two cars, one was mine, the other was a friend's... It's not that common, but when it occurs it' a PITA to track down because you don't get any other signs other than your garage door not working...
Good topic. I have same problem and i thought i need a new battery for my remote. Boy you learn a lot here at the forum. "LONG LIVE THE FORUM" :cheers: :cool:
