Did The TB Bypass--Opinions on My Routing
I did the TB Bypass this morning-- Do you think the routing [5/8 heater hose], is it safe??? Any long term problems???
It goes under the air duct.
Re: Did The TB Bypass--Opinions on My Routing (Wayne88)
I would get it away from the A/C lines. They are very thin aluminum, and if they are rubbed, they could get a leak....
Re: Did The TB Bypass--Opinions on My Routing (bogus)
I spaced it away from the aluminum.
I routed it this way to avoid that crowded area near the TB--the AIC valve, Etc...
:chevy
Re: Did The TB Bypass--Opinions on My Routing (Vett-eight-nine)
What's the advantage to this mod, guys?
If you check the archives, you will see claims of added horsepower.
These points have all been covered before several times in previous threads .
If you search 'Throttle Body Bypass' in C4 Tech/Performance, you will see the past threads on this subject
I found it possible to route it under my ac compressor, directly to intake manifold. As you can see in this pic, or should I say what you can't see in this pic :D
I routed mine the same a Agent 86. I believe the hose is a 5/8 and get one with a preformed 90 degree bend. Hook the short radius 90 at the block, route under the IAC & TPS, and under the air conditioner line. It seems to fit just fine.
Re: Did The TB Bypass--Opinions on My Routing (AGENT 86)
Re: Did The TB Bypass--Opinions on My Routing (JB666)
ya just HAD to sneak that engine pic in here, didn't you!! :jester
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I like the yellow paint. Is it powder coating? How did you smooth out the mag valve covers? Looks great. :thumbs:
I went from a 5/8" to a 1/2" and back to a 5/8". That way I could route the 1/2" under the TPS without interference. I makes getting to the IAC a pain though.
Like so...
http://home.houston.rr.com/c4vette/TB_by-pass.html
I like your routing - looks very clean.
[Modified by Mike263, 6:28 PM 4/28/2004]
Like so...
Re: Did The TB Bypass--Opinions on My Routing (ZAD54)
ya just HAD to sneak that engine pic in here, didn't you!! :jester :iagree: :jester
