85 to come alive! Replacing ALL underhood sensors - what is involved?
Old 04-21-2004, 10:21 PM
Togo
Support Corvetteforum!
Togo's Avatar
Default 85 to come alive! Replacing ALL underhood sensors - what is involved?
i'm getting back into the game "slowly" and have just purchased the cam for my first motor swap - so for total reliability and streetability, i am thinking of replacing ALL the sensors under the hood - what am i getting myself into?
just a few off the top of my head
Cold Start injector
Temp Sensor
Knock Sensor
MAF
help me fill in the rest of the blanks
:seeya
Old 04-21-2004, 10:39 PM
bogus
bogus's Avatar
Default Re: 85 to come alive! Replacing ALL underhood sensors - what is involved? (85_togo)
O2 Sensor
TPS
IAC
Oil Pressure Switch & Oil senders
Old 04-22-2004, 12:26 AM
JAKE
JAKE's Avatar
Default Re: 85 to come alive! Replacing ALL underhood sensors - what is involved? (bogus)
IAC MOTOR
TPS
02 SENSOR
AIR TEMP SENSOR
COOLANT TEMP FOR FAN
COOLANT TEMP FOR ECM
COOLANT TEMP FOR DASH GAUGE
MAF SENSOR
KNOCK SENSOR
ESC MODULE
EGR VALVE
A.I.R./EGR SOLENOIDS
FUEL VAPOR CANISTER SOLENOID
MAF POWER RELAY
MAF BURN-OFF RELAY
FUEL PUMP RELAY
EGR TEMP SWITCH
PCV VALVE
OIL TEMP SENSOR
OIL PRESSURE SENDER (DASH GAUGE)
OIL PRESSURE SWITCH (FUEL PUMP)
COLD START INJECTOR SWITCH
A/C STUFF
And a partridge in a pear tree.
Easy to install but they'll run up in ther $$$ to do them all.
Jake
Old 04-22-2004, 08:56 AM
rick lambert
rick lambert's Avatar
Default Re: 85 to come alive! Replacing ALL underhood sensors - what is involved? (JAKE)
You're very ambitious :thumbs: -my theory-if it ain't broke-don't fix it :auto:
Old 04-22-2004, 09:04 AM
HeeHaw89
HeeHaw89's Avatar
IAC MOTOR
TPS
02 SENSOR
AIR TEMP SENSOR
MAF SENSOR
KNOCK SENSOR
ESC MODULE
EGR VALVE
MAF POWER RELAY
MAF BURN-OFF RELAY
FUEL PUMP RELAY
EGR TEMP SWITCH
PCV VALVE
OIL TEMP SENSOR
A/C STUFF
Jake
Yeah that will cost ya, but peace of mind knowing they are all new is a good thing as well.
Anyone know what the total would be for all that? :crazy:
Old 04-22-2004, 10:41 AM
jmrl98
jmrl98's Avatar
Default Re: 85 to come alive! Replacing ALL underhood sensors - what is involved? (HeeHaw89)
I've heard the 85 MAF burnoff relay is rather pricey - let alone getting to it. 89 is easy to get to and way less expensive.
Old 04-22-2004, 02:15 PM
SunCr
SunCr's Avatar
Most sensors are fairly reliable with the few duds long since replaced by better designs when the car was under warranty or the dealers picked them up under a Service Bulletin. One I believe, the cold start injector, is out of production. I'm somewhat skeptical too of Bosch's claim that you need to replace the O2 every 25k, but maybe that's because I live in a State with a 5yr/50K warranty on emissions parts (and none of the OEM's have faced a recall for O2 failures). If you don't own a scanner, you might want to spend your $'s on that and then compare what you got with typical values.
Old 04-22-2004, 02:27 PM
Togo
Togo's Avatar
Default Re: 85 to come alive! Replacing ALL underhood sensors - what is involved? (SunCr)
i was able to score diacom for a fairly decent price but the car is not running at this time - and i am sure all of the sensors will be readily available once that motor is pulled - agreed? the if it ain't broke don't fix it theory is usually mine, but since this will be my daily drive and hasn't been started in over a year and a half i am a bit skeptical - so whilt the car is apart, i'm gonna replace them all
guess i should get to ordering
anyone got any good sources for replacment parts?
***EDIT*** guess i also should have asked - are there any sensors that i should "upgrade" to newer models sensors for reliability? or should i stick with everything from the 85?
[Modified by 85_togo, 12:39 PM 4/22/2004]
Old 04-22-2004, 03:43 PM
GRX
GRX's Avatar
...replace the spark module with an updated one (per G Kilebrew).
Old 04-22-2004, 03:45 PM
Togo
Togo's Avatar
Default Re: 85 to come alive! Replacing ALL underhood sensors - what is involved? (GRX)
:confused: spark module? is that the thing on top of the distributor?
also - which sensors would be BEST to change out while the motor is OUT? figure i can replace the few while it's out, and the rest once it's back in (otherwise i fear the motor may never make it back in due to procrastination!)
[Modified by 85_togo, 1:47 PM 4/22/2004]
Old 04-22-2004, 06:32 PM
JAKE
JAKE's Avatar
No the ESC module is bolted one the passenger side directly across from the battery.
The air temp sensor (underside of the plenum), the oil pressure sender and oil pressure switch (near the distributor) are three that should be changed with the engine out.
The coolant temp sensor for the ECM and the cold start injector switch can be done with the engine in the car, but there are lots of stuff in front of them, so if I had a choice, I'd change them with the engine out too.
Most of the others are best left out until the engine is installed or you run the chance of breaking them as the engine is lowered into the engine bay.
You'll be out of several hundred dollars to do them all. Ecklers and Mid-America catalogs have most of them listed with the prices. You can probably get better prices from AutoZone, etc.
Jake
To 85 to come alive! Replacing ALL underhood sensors - what is involved?
Quick Reply: 85 to come alive! Replacing ALL underhood sensors - what is involved?
