POLL - What oil filter do you use on your Corvette?
I don't know if this survey has been done before on the forum (it probably has), but I was just curious.
I'm about to change the oil in my car in light of the great weather we're having, and I wanted to know what everyone else uses.
Feel free to add your choice to the list.
Received 1,400 Likes
Re: POLL - What oil filter do you use on your Corvette? (TheCorvetteKid)
K&N at the moment.
Re: POLL - What oil filter do you use on your Corvette? (rons85)
Since they no longer produce PF25, I switched to PF1218...but then again, all my small block powered cars are running the PF1218. :thumbs:
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: POLL - What oil filter do you use on your Corvette? (TIMSPEED)
Re: POLL - What oil filter do you use on your Corvette? (jackdaroofer)
wasnt sure about the K&n too much.. i think it was just me but does the drainback valve affect oil level any way?? i thought it was preventing oil from coming back to the pan so i was never sure if the level was right. I do know when i used the k&n though i put the same amount of oil in and it read at a different level. i took it off after 25 km and put in a delco one. :smash:
Re: POLL - What oil filter do you use on your Corvette? (vader86)
K&N at the moment.
Re: POLL - What oil filter do you use on your Corvette? (96POLO)
I use the STP filter ST-373
My car does not have a trans cooler, and this filter holds nearly 2 qt.s
This way i have more oil, which gives longer oil life. My car holds 7 qt.s w/ a stock pan.
Re: POLL - What oil filter do you use on your Corvette? (SOVAIN1)
Since they discontinued the PF25, I am now running the PF454...the replacement filter for the PF25. :chevy
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
:beatdeadhorse:
I use K&N. The oil filter hangs down low enough, and my lowered car with an oil cooler makes it <4" above ground. The K&N has a THICK casing on it, so its less likely to get punctured or torn from road rash and debris.
Re: POLL - What oil filter do you use on your Corvette? (CentralCoaster)
Well... the car came with an AC Delco PF52, so that is what I have used ever since. No complaints here.
Mike
Mike
I use the 1218 on small and big blocks now.
