94 LT 1 transmission problem
Re: 94 LT 1 transmission problem (American Muscle)
I have a 94 automatic conv . When i put the car in the overdrive or drive setting it slips in 1st gear , but when shifting manually it works 80% better . Only 1st gear has this problem .The fluid is not burnt but does need to be changed. Thanks for the help. :banghead:
When I say flush, I mean FLUSH - replace every last drop. It's not hard, but it is time consuming... and requires removing the top transmission coolant line from the radiator. Otherwise, pay a shop about 100.00 to exhange all the fluid.
when most transmission tuneups are done, only about 1/3rd of all fluid is removed... not enough...
Elite Torch Red Member
Email tomdcarguy@aol.com, he's in Howell and is the best tranny guy you'll find in Jersey(or anywhere else for that matter). He's very busy right now and is prepping his car for the Hot Rod Pump Gas Drags in Memphis, but we'll be back on May 3rd or 4th. Give him a shout.
Manual first or second has accessed the intermedaite boost valve, this gives higher line pressure. This could be a "restricted" filter, front pump is losing its volume, to much wear (clearance) at the sealing rings, forward clutches are close to being gone because of a apply seal (toen) or cracked piston, etc.
