Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-03-2004, 01:01 AM   #1
CentralCoaster
CF Senior Member
CentralCoaster's Avatar
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default How do I make custom-formed rubber hoses?
Is this possible? I need to make some for my power steering cooler I installed. Needs to be the nylon reinforced (pressure rated) hoses.
Is it as simple as buying standard hose and boiling it or using a heat gun or something of the sort?
I'm too lazy to do a Google search, and you guys are always johnny on the spot anyways. :D :lurk:
CentralCoaster is offline   Reply With Quote
Old 04-03-2004, 01:22 AM   #2
Corvette Kid
Large Upstanding Member
St. Jude Donor '04-'05-'06-'07
Support Corvetteforum!
Corvette Kid's Avatar
Default Re: How do I make custom-formed rubber hoses? (CentralCoaster)
:lurk: Now there's a question I haven't seen before..........
Corvette Kid is offline   Reply With Quote
Old 04-03-2004, 03:08 AM   #3
Mez
CF Senior Member
Location: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
I don't think a heat gun will work very well. The heat is too hard to regulate.
I have not tried this, but it should work. Slip the hose over some soft copper tubing. The copper tube should go thru the entire hose length. Use a little water/soap to make it slip on easier.
Bend it to the shape you want then place in oven at 325 degrees for 10 minutes. Take it out and let it cool slowly.
I am guessing on the temp / time here. Obviously, too hot or too long will totally melt it. Too little and it won't change shape. You may want to experiment with a small piece of hose at various temps and times to see what happens before doing the final part. I guess the right temp will be 325-400 degrees but check the temp rating.
You may want to do this while the wife/significant other is out shopping (smell).
Mez is offline   Reply With Quote
Old 04-03-2004, 04:46 AM   #4
Jaxian
CF Senior Member
Jaxian's Avatar
Default Re: How do I make custom-formed rubber hoses? (Mez)
This is going to depend alot on which lines you want to change on your power steering. If you look closely at the hoses you will notice that one just uses regular high temp oil rated hosing and is held in place with standard hose clamps. This is the low pressure return side. You can run any high quality high temp hose you would like on this side that is rated for oil. The other line coming out of the power steering pump has flare fittings and factory crimped ends on the rubber hosing, this is the high pressure side. I am assuming since you put your own power steering cooler on you didn't use the factory cooler (the retro-fit kit is no longer available to my knowledge), so you can't just retro fit the factory power steering cooler lines on to yours.
If the hose routing goes Pump ++> Steering Rack --> Cooler --> Pump again, you should be okay using standard lines as the only high pressure area is the one marked by the +'s and your cooler is in the low pressure return line. Just use high quality oil hoses and good fittings/clamps. The oil hose isn't hard to find and while a bit pricey isn't too bad, much cheaper than steel braided. Also make very sure you flush the oil through the whole system until its clean, on earlier cars the teflon rings on the spool valve where much harder than the aluminum housing. This tended to cause lots of wear and failures from the resulting junk in the fluid. If you have a late car don't sweat it as the factory went to iron housings to fix the problem in 1988. Lots of early cars have new racks already because of this. Since the C4 racks where so sensitive to dirt some people put in filters, not sure exactly where to get them, but if you are in buying hoses and moving stuff around you could look into it. Hope this helps.
[Modified by Jaxian, 1:49 AM 4/3/2004]
Jaxian is offline   Reply With Quote
Old 04-03-2004, 10:42 AM   #5
korvette4u
CF Senior Member
korvette4u's Avatar
:D :lurk:
How do I make custom-formed rubber hoses? your answer to fix your lazyness. becuz if you can't. what the sense to explain anything to you? :beatdeadhorse: :D :D :lolg: :lolg: :lolg: :lolg: :lolg: :lolg:
korvette4u is offline   Reply With Quote
Old 04-03-2004, 01:10 PM   #6
joeveto
CF Senior Member
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
joeveto's Avatar
Maybe I'm not understanding what you want to do. Why don't you just buy stainless line, and then bend and flare it?
Will this not work?
The other option, would be to create your desired bends using multiple links of hoses, connected by fittings. Might look like crap, and I can't speak to the reliability of doing this...
joeveto is offline   Reply With Quote
Old 04-04-2004, 04:52 AM   #7
CentralCoaster
CF Senior Member
Default Re: How do I make custom-formed rubber hoses? (joeveto)
I need formed hoses, because the bends would be too tight otherwise, and kink the hose.
The factory hoses are formed for this same reason, plus they have to clear the PS pulley.
I am routing the hose on the return side, so I guess I can go with standard hose.
I was in the hardware store yesterday looking at dishwasher stainless braided hose, they can bend pretty tight without kinking...but I think I'll try the oven trick as mentioned.
I just figured this sort of thing was commonly done among hotrodders... I guess not. Or maybe you guys are just waxers?:jester
I'm going to Google now. :seeya :auto:
Old 04-04-2004, 12:06 PM   #8
BLACKVETTE95
Junior Member
BLACKVETTE95's Avatar
I do like the oven method, but .....
let's say you need 90 degree bend. when it forms in the pipe, how would you take it out? Or do you cut the metal pipe? Wouldn't it be better to boil in water so that as it heats, it will not melt onto the pipe?
just a thought....
BLACKVETTE95 is offline   Reply With Quote
Old 04-04-2004, 01:28 PM   #9
smar
CF Senior Member
smar's Avatar
Default Re: How do I make custom-formed rubber hoses? (BLACKVETTE95)
I would look for hydraulic equipment store in your area. They will re-crimp new hoses to the old fittings. you will be able to choose type of hose and the lenght. Even some automotive stores like NAPA might be able to do it.
:steering:
smar is offline   Reply With Quote
Reload this Page How do I make custom-formed rubber hoses?
Tags
bend, bends, custom, factory, fit, formed, high, hose, hoses, make, making, mold, preform, pressure, rubber
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
