91 vette please help with data
can someone help with this data?? this was taken at idle. coolant temp174.6, throttle sensor .062 volts, engine rpm 764, o2 senser 720 mvolts, 02 cross counts 37, block learn 120, blk lrn cell 4, integrator 127, idle air mtr pos 27 steps, map sensor 1.35 volts, manifold air tmp 77.0 f, spark advance 17.1, knock senser 15, knock retard 0, injector pulse 1.7ms, engine run time 876 secondslearn control enabled, rich lean flag rich, loop status closed. i set timing at 6 and fuel pressure is at 43 psi.
