Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-17-2004, 06:56 PM   #1
Tourney3p0
CF Senior Member
Tourney3p0's Avatar
Default Symptoms of a bad EGR?
I read somewhere in the archives that a bad EGR could possibly cause a sound like lifter clatter a few minutes after the car is started.
My car has a sound like that (not a tick exactly, more like a clack) that starts around the time the car goes closed loop. I was almost certain that it was timing chain slap so I've bought a Cloyes set but haven't put it on yet.
Yesterday I got a code 32 immediately after starting my car, so I started poking around the archives and came across a couple of people saying a bad EGR could cause a similar sound. My EGR valve and tube are intact but my AIR system is gone.
I'd consult my Helms manual to see what it says about an immediate code 32, but I'm in the process of moving. It's here and I'm there.. anyway, I've always heard code 32 should come up after driving a few miles, not immediately.
I'm not really looking for how to fix code 32.. the code didn't come back after I stopped the car and restarted it. I know it's EGR, I'm just wondering if maybe that random code 32 could be related to my clatter under the hood.
Tourney3p0 is offline   Reply With Quote
Old 03-17-2004, 07:57 PM   #2
65Z01
CF Senior Member
Cruise-In II Veteran
65Z01's Avatar
Send a message via AIM to 65Z01
Default Re: Symptoms of a bad EGR? (Tourney3p0)
I've never heard of clatter from an EGR but when the code 32 comes up immediately after startup the ECM is detecting the EGR valve to be open when it has not been commanded to open.
While cruzing in closed loop mode the ECM will command the EGR valve to open and also throw a code 32 if it doesn't detect (via the EGR Temp Switch) that it has opened.
When you get around to servicing the EGR system there is a diagnostic method on my site.
65Z01 is online now   Reply With Quote
Old 03-17-2004, 11:21 PM   #3
VAHROOM
CF Senior Member
VAHROOM's Avatar
My EGR only coded after 20 minutes of driving. Not right away. I tested it with a piece of vacuum hose and tested its ability to hold vacuum. It failed. I replaced it and code 32 was gone. Just suck in on the vacuum hose connected to the nipple on the valve. Watch to see if the plunger moves. Hold the hose closed and see if it leaks down. If it moves and doesn't leak down. You are good to go.
VAHROOM is offline   Reply With Quote
Old 03-18-2004, 11:54 AM   #4
jmrl98
CF Senior Member
jmrl98's Avatar
Default Re: Symptoms of a bad EGR? (VAHROOM)
That clack or ticking is the solenoid or switch for the EGR. It is happening to my 85 every time I start it up. The noise is very audible, different from the injectors, and definitly from the passenger side by the EGR. I'm going to change the solenoid (kit from midamerica) and clean the EGR, and see what the results are. The shop manual says that a malfunctioning EGR will cause idle drop upon deceleration, which I do notice but it is not like the thing is going to stall. I'm hoping the EGR cleaning and switching of he solenoid will clear up the deceleration issue and stabilize my idle a little (not that my idle jumps too much anyway). :seeya :steering:oh yeah, I'm not getting any codes, either.
[Modified by jmrl98, 10:55 AM 3/18/2004]
jmrl98 is offline   Reply With Quote
Old 03-18-2004, 10:43 PM   #5
CentralCoaster
CF Senior Member
CentralCoaster's Avatar
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: Symptoms of a bad EGR? (jmrl98)
I think I have the same problem. THe smog tech said the EGR was not responding like it should (yet it hasn't thrown any codes :confused:) I'm also hearing what I thought was injector ticking coming from near cylinders 6 and 8 (which is near the EGR solenoid on my 85).
I picked up a vacuum pump, and i'll diagnose everything tomorrow if I get a chance. New Delco EGR valve is already on its way..
[Modified by CentralCoaster, 7:44 PM 3/18/2004]
CentralCoaster is offline   Reply With Quote
Old 03-19-2004, 01:18 AM   #6
Jloshotz
CF Senior Member
Jloshotz's Avatar
Send a message via AIM to Jloshotz
Check your plugs in cyls # 5 And # 6. When my EGR went bad In my 91 tuned port 5.7 z28 # 5 plug was detonated so bad it was rediculous. No Ground bar and electrode was actually hollowed out....scary
:eek: :eek: :eek:
Jloshotz is offline   Reply With Quote
Reload this Page Symptoms of a bad EGR?
Tags
1991, 1997, 57, bad, corvette, egr, lt1, port, skipping, solenoid, symptomps, symptoms, symptons, tuned, valve, z28
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
