'86 Convertible...new top install...driver's side rear pin...
Re: '86 Convertible...new top install...driver's side rear pin... (UDLUV12)
It sounds like the latch underneath the boot may be sticking. Check there first. If you did new weatherstrip it could just be a little tight. Try latching the rear pins first then do the front. Once the top streches a little bit you should be fine. :cheers:
