Check out this inside of this fuel filter........
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
We did vetteweiser's fuel filter which hadnt been done in a very long time.........look at this....
Elite Torch Red Member
Re: Check out this inside of this fuel filter........ (My 95)
I'm willing to bet mine looks worse, I'm almost afraid.
Re: Check out this inside of this fuel filter........ (scorp508)
couldnt pass any air through this one :nonod:
Re: Check out this inside of this fuel filter........ (GrandSportC3)
You sure that's not the original filter? Hey don't laugh i have a buddy that doesn't change his oil, says he just tops it off every few months and after awhile it's all new oil. :eek:
Re: Check out this inside of this fuel filter........ (Black87c4)
How did the vette get any fuel? :confused:
Its a napa filter (the one cut in half)
and hows that song go?? I GOT THE POWER!!
wow!!!!! what a difference! My baby is back to life now!!
That and the fact its a very cold 54 degrees here probably helps. Open lid mod and a TB bypass is due this friday, time for more power :D
I cant believe how bad my filter was though, thats sickening and :crazy: :crazy:
Re: Check out this inside of this fuel filter........ (barkingowl)
I have no idea :confused:
Re: Check out this inside of this fuel filter........ (vetteweiser)
The same way a virgin gets pregnant :D
:lolg: :lolg:
Yuck :U Some of that crap may have gotten past the filter and into the injectors. Let us know how it idles/runs with the new filter.
You might consider pulling the sending unit, syphoning the tank and seeing if anything is in there. Remove the new filter and blow out the lines with compressed air. It sounds like a lot of work, but you can do it in an afternoon or two.
