Does anyone use Lucas Oil Products?
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Anyone use the stuff? I've seen it around alot and was thinking about running the 75w90 synthetic in the diff.
:cheers: -JRC-
:cheers: -JRC-
Re: Does anyone use Lucas Oil Products? (JrRifleCoach)
I thought about using their cleaner once in my '94 before i did a rebuild. Read up a lot and talked to a lot of peole and they said it's really not good stuff. Still no experience with it personally, but from what I heard it's best not to.
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
I use it in my 79 and in the monte Carlo. I think it works pretty good and I've met a lot of folks who do as well. :yesnod: I've used the oil stabilzer and the power steering additive. The power steering stuff worked really great. Quiet as a baby now.
[Modified by killain, 6:48 AM 1/31/2004]
Re: Does anyone use Lucas Oil Products? (killain)
Don't know about the oil additive, good for a quick and dirty fix on a tired old engine maybe, but the power steering stuff has really worked well for me on several cars. Fixes leaks and squeaks, does what it says on the tin. :)
used the pwr steering and trans additive,,, and they both worked wonders... on the rear, stay with gm posi additive and synth mobil 1 .... :thumbs:
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Re: Does anyone use Lucas Oil Products? (vinnies87)
The additive is great, if you like your gear oil or ATF to turn into a solid rock on cold mornings. Kinda makes it hard.... er... impossible to shift into some gears.
Be careful how much you put in. :yesnod:
I had a slight slip with my 84 automatic at about 40 mph. I changed the trans filter, trans fluid and added a quart of the Lucas trans lubricant.
I no longer have the slip, so I would have to say with my issue the Lucas lubricant did its job.
Re: Does anyone use Lucas Oil Products? (Brimis)
Funny stuff this Lucas. Looks like snake oil, smells like snake oil, Hell it even tastes like snake oil.
But .....It seems to work! :confused: :confused:
Location: If you don't weigh in you don't wrestle Road America
Re: Does anyone use Lucas Oil Products? (britvette)
I have Royal Purple 75w90 in my differential (96) and it works great, three quarts and no additive. Lays two black marks with my 315's and it seems to let the rear wheels turn easier. I was hesitant untill the guys from Melrose T-tops who raced C4's in the World Challenge (now Speed GT) series said that was all they ran so I said what the hay. Works for me :thumbs:
I've got the power steering stuff in the v8 minivan and it has pretty much stopped leaking. I also used their stuff for ticking lifters in the van- the engine had been sitting for several years and now most of the time the lifters are quiet. I was impressed because while I was dumping the stuff in the engine, I was thinking "snake oil" :)
I used their rear diff fluid on my recent gear oil change. The bottle indicated no additive was necessary so I didn't use any. No problems at all and lays perfect posi all day long...
Re: Does anyone use Lucas Oil Products? (CentralCoaster)
I wouldn't call Lucas, snake oil, but rather, a quick fix. A quick fix, like trying to get my dad to stop smoking by stealing his cigarettes. :lol:
