Top speed of a C4
Top speed of a C4
Can any one tell me the top speed of the C4 with the L89 engine???
Has to be standard as well.
Is there anything that has GM certifaction???
Please help me i cant find anything :confused: :confused: :confused:
Re: Top speed of a C4 (jason_c)
I don't think Gm certified that a vette will do a certain top speed but a few records are certified you just have to look.
A ZR-1 broke records in a 24 hour speed test.
A few car magazines have tested them depending on year this site has good info
http://www.corvetteactioncenter.com/specs/index.html
Good luck
Good luck
1984 most magazines reported that the c4 was an honest 140mph car then the tpi motor came about in 1985 and the hp went to 235 and the mph jumped to 150 now for whatever reason the hp only climbed 10 more up to 1991 but top speed kept growing to around 160mph then the hp claims of the lt-1 motors took a 55 hp leap and the fastest top speed I've read has been 165mph until the zr-1 went 180mph-178mph depending on who was testing, elevation temperature,etc,these older vettes a reasonably cheap used for how fast they are. To this day you have to spend alot of money to go as fast as these cars can take you. They are just so damn slippery! I lovem :chevy
Re: Top speed of a C4 (Red Hot 916spd)
......hp only climbed 10 more up to 1991 but top speed kept growing to around 160mph
....until the zr-1 went 180mph-178mph depending on who was testing
I read a MT ....April 1992 (maybe march or may, but i think it was april). That had top speeds tested.
The stock LT-1 Coupe they tested top'd out at 170-172 MPH with the most accurate measurement system possible, timing lights across a known distance.
If you dont believe me check out that magazine.
That number strikes me as amazingly high. Ive seen Road and Track tests where that was the best a ZR-1 could achieve. However RT is known as being slower for some reason.
L98's should top out at 160, although dont hold me to that since I know more about the LT-1 cars.
Ive had my hot cam'd LT-1 at a speedo indicated 155 for a few seconds.
Re: Top speed of a C4 (dizwiz24)
L98's should top out at 160.....
Re: Top speed of a C4 (vinnies87)
i have seen 167 on the sppedo of my 96CE, and 163 on my 93 with 2.59 gears IN DRIVE
Re: Top speed of a C4 (vetteman9368)
I was travelling at 80mph when i hit the gas all the way down for a bit more than half a mile. There i reached 125mph. Auto with 3.07(G92 rear)
Re: Top speed of a C4 (scorp508)
It took me a good 3-4 miles to get to 154 in my '87 when stock and the miles ticking off from 145 and up were sooooo slow. :D
Stock L98: 154 where the last digits I saw. The world was moving too fast for me to take my eyes off the road.
Re: Top speed of a C4 (VictorRussell'92)
I had mine around 139 with the targa off, I decided to lift, that was totally stock. I bet if I keep the top on, remove the mirrors I would hit 170 with these mods, maybe more with for a second with a shot of NOS.
Re: Top speed of a C4 (GusBustamanteJr)
153,,, got scared,, she would have done a little more......... :D
My butt is still puckering :eek: :eek:
Never again
Never again
I've run over 150 a few times on the highway, but mostly on the track, but you need to hear about my friend and "go faster mentor" - Ed Van Scoy. His '85 C4 is faster than most :D
http://www.corvette-paradise.com/ed.html
:flag
:flag
Re: Top speed of a C4 (Epyon127)
Good luck
Good luck
Volkswagen "broke" the ZR-1 record recently. but VW pulled the plug on their W-12 motor and it never went into production so their numbers were never recorded as official records. That still leaves the ZR-1 as the record holder in those catagories show on the page.
