Help Please! LT1 with no spark after cam change
6th Gear
I am not getting any spark out of the coil.
Here is the series of events:
This is 1994 corvette LT1 that I put in my 66. I had the wiring harness reworked and had a VATS module installed. I installed the reworked harness, wired up the battery, and it engine ran perfectly.
I then swapped the cam with an "LT4 hot cam" and now it won't start. I have fuel, compression, but no spark. I traced out the wiring and everything looks OK. I check voltage at the coil connectors and found 12V (not sure which pins do what).
Any help to narrow the problem down would be greatly appreciated.
Thanks, John
:confused:
Thanks, John
:confused:
Re: Help Please! LT1 with no spark after cam change (johnnybtexas)
hi,did you make sure that the opti -spark unit fit flush with the cam and that its timed on the money?good luck greg84 :cool:
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Re: Help Please! LT1 with no spark after cam change (greg84)
