Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-09-2004, 05:36 PM   #1
montie98
CF Senior Member
montie98's Avatar
Default Upper Radiator hose not getting hot,. Bad Thermostat?
The car just keeps getting hotter with the right amount of coolent then the oferflow tank starts overflowing with lots of pressure meanwhile the upper hose is ice cold????
montie98 is offline   Reply With Quote
Old 01-09-2004, 05:49 PM   #2
Aggravated4life
CF Senior Member
Cruise-In II Veteran
Aggravated4life's Avatar
Default Re: Upper Radiator hose not getting hot,. Bad Thermostat? (montie98)
Maybe the stat is stuck closed?Id check there first.
Aggravated4life is offline   Reply With Quote
Old 01-09-2004, 06:01 PM   #3
vinnies87
CF Senior Member
St. Jude '03-'04-'05-'06-'07
vinnies87's Avatar
Default Re: Upper Radiator hose not getting hot,. Bad Thermostat? (Bill's86Coupe)
:iagree: :thumbs:
vinnies87 is offline   Reply With Quote
Old 01-09-2004, 07:37 PM   #4
jackdaroofer
CF Senior Member
Cruise-In I Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Support Corvetteforum!
jackdaroofer's Avatar
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
Default Re: Upper Radiator hose not getting hot,. Bad Thermostat? (vinnies87)
Quote:
:iagree: :thumbs:
:iagree: Too! For some reason I go through a thermo a year on my 88
but let me ask anothe question. How old is the top hose? Those things delaminate internally and the delaminated portion can act like a flapper valve and cut off circulation.
Is the heater putting out hot air?
:seeya
:steering:
jackdaroofer is offline   Reply With Quote
Old 01-09-2004, 08:49 PM   #5
tlc85
CF Member
is your fan comming on?
tlc85 is offline   Reply With Quote
Old 01-10-2004, 02:26 PM   #6
86VetteBill
CF Senior Member
Send a message via AIM to 86VetteBill
Take your time removing those 2 thermostat housing bolts. They might be hard to unscrew. Go too fast with too large of a ratchet and you'll snap one of them off like I did.
That's not fun, especially when you're drilling and tapping a new one and the tap broke!! Taps don't drill out - even with hardest drill bits. I chiseled most of it out.
86VetteBill is offline   Reply With Quote
Old 01-10-2004, 04:14 PM   #7
JAKE
CF Senior Member
JAKE's Avatar
Default Re: Upper Radiator hose not getting hot,. Bad Thermostat? (86VetteBill)
I vote for a stuck stat too; happened to me last spring.
If that is the case, try to find a replacement that, should it fail, will fail in the open position. They cost a bit more, about $8.00 but won't leave you stranded should it happen again.
I bought mine at O'Reilly's Auto Parts but I'll bet AutoZone sells them too.
Jake
JAKE is offline   Reply With Quote
Reload this Page Upper Radiator hose not getting hot,. Bad Thermostat?
Tags
03, 2003, bad, c5, cold, corvette, hose, hoses, hot, location, radiator, thermostat, top, tube, upper
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
While I'm in there getting out of hand - need some sympathy jeffnles1 C3 Tech/Performance 30 12-25-2001 02:10 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
