Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-06-2004, 08:22 AM   #1
Tourney3p0
CF Senior Member
Tourney3p0's Avatar
Default Metal rubbing sound from my wheel?
Yesterday my car started making a metal rubbing, almost a screeching sound coming from my passenger side rear wheel. I can tell that it coincides with how fast my wheel is turning, as the rubbing gets quicker as the car does.
It sounds like metal on metal. I took the wheel off and inspected, and there was nothing obvious wrong in there. I removed the pads (Hawk Performance) to inspect them and they looked fine with no uneven wear. There is no horizontal or vertical movement in the wheel.
It almost sounds like brake pads or something grinding into the rotor, so I'm going to pick up a dirt cheap set today and swap it out for a few minutes so I can rule them out. What else could it be? Wheel bearing?
Tourney3p0 is offline   Reply With Quote
Old 01-06-2004, 08:29 AM   #2
Tourney3p0
CF Senior Member
Tourney3p0's Avatar
Default Re: Metal rubbing sound from my wheel? (Tourney3p0)
I'm thinking also maybe a stuck caliper. Is there any way to troubleshoot this?
Old 01-06-2004, 08:33 AM   #3
bogus
CF Senior Member
Send a message via Yahoo to bogus
if it ain't the pads... check the wheel bearing or u-joint.
the easiest way to check for a bad caliper is to grab the piston with big **** pair of channell locks and SQUEEZE! if nothing else, it will free up the piston.
also, make sure the pins are clean and well lubed with anti-sieze!!!
[Modified by bogus, 8:34 AM 1/6/2004]
bogus is offline   Reply With Quote
Old 01-06-2004, 09:50 AM   #4
Tourney3p0
CF Senior Member
Tourney3p0's Avatar
Default Re: Metal rubbing sound from my wheel? (bogus)
When I was checking my brake pads, I completely removed them and used a C-clamp to push the piston back down. I guess that means it's not frozen up, but I wasn't sure if this was a sufficient test.
It doesn't sound like any wheel bearing I've ever heard. Still, I'm really not putting much hope in it being the brake pad since everything looked to be in great shape, visually. The only thing I can think of is one of the rocking retainer pieces on the outside brake pad was a little loose, so maybe I have some movement in there. I tightened it up and it didn't seem to help.
Old 01-06-2004, 09:51 AM   #5
jp2002ls1
CF Senior Member
jp2002ls1's Avatar
Send a message via AIM to jp2002ls1
Front or Rear?
If rear, check your parking brake.
If front check your caliper, there may be a stone stuck between your pad and rotor, or check wheel bearing for play.
jp2002ls1 is offline   Reply With Quote
Old 01-06-2004, 09:54 AM   #6
Tourney3p0
CF Senior Member
Tourney3p0's Avatar
Default Re: Metal rubbing sound from my wheel? (jp2002ls1)
Quote:
Front or Rear?
It's rear, but I have no working parking brake. It was this way when I bought the vehicle. I have plans to fix this eventually but I'm working on some other nagging issues at the moment. This squealing that just came up, I am considering a little more serious than a nagging issue.
Old 01-06-2004, 10:51 AM   #7
85RIT
CF Senior Member
85RIT's Avatar
Send a message via AIM to 85RIT
A u-joint would be more of a tick....
Maybe your pads are just wore, is the sqeaker hitting the rotor??
Other then that I would vote wheel bearing.
85RIT is offline   Reply With Quote
Old 01-06-2004, 10:57 AM   #8
Tourney3p0
CF Senior Member
Tourney3p0's Avatar
Default Re: Metal rubbing sound from my wheel? (85RIT)
Just out of curiosity, what would a wheel bearing sound like? The ones I've heard in the past sound like a high pitched squeal, or maybe a chirp. Also I've almost always had vertical 12-6 movement. Admittedly though, my experience with bad wheel bearings is limited to say the least.
It sounds almost exactly like something scraping the rotor as it turns, but I'm not seeing any grooves in the rotor. The pads look almost brand new, and I don't see anything at all that would be touching the rotor in a normal, working setup.
Old 01-06-2004, 11:06 AM   #9
Steel Blue 91
CF Senior Member
Steel Blue 91's Avatar
With the wheel and tire in place, raise the car. Movement by pushing and pulling at the 12 and 6 position would indicate a wheel bearing. Movement at the 9 and 3 positions indicates suspension issues.
Steel Blue 91 is offline   Reply With Quote
Old 01-06-2004, 11:08 AM   #10
Tourney3p0
CF Senior Member
Tourney3p0's Avatar
Default Re: Metal rubbing sound from my wheel? (Steel Blue 91)
I don't have any horizontal or vertical movement in the wheel. Could it still be a wheel bearing without any vertical movement?
[Modified by Tourney3p0, 10:08 AM 1/6/2004]
Old 01-06-2004, 11:48 AM   #11
scorp508
CF Senior Member
scorp508's Avatar
Generally no because when a wheel bearing goes the bearing has worn so that there is excessive clearence allowing the unit to rock in itself.
scorp508 is offline   Reply With Quote
Old 01-06-2004, 11:52 AM   #12
Tourney3p0
CF Senior Member
Tourney3p0's Avatar
Default Re: Metal rubbing sound from my wheel? (scorp508)
:cheers:
I appreciate the help. I'll see what I can do and follow up when I figure it out.
Old 01-06-2004, 12:15 PM   #13
Trog
CF Senior Member
Trog's Avatar
Did you try jacking it up & turning the wheel by hand?? It could be somthing even rubbing on the half shaft?? Like a disconnected e-brake line?? :smash:
Trog is offline   Reply With Quote
Old 01-06-2004, 12:42 PM   #14
chb88
CF Senior Member
I am doing wheel bearings on a 94 now and the sound I was getting was a grinding, much like the sound you get when you first apply the brakes on a rusty rotor. In my case I had about 3/16" movement at 6 and 12 o clock. Could something have lodged between the ABS sensor and the toothed rotor on the hub? Try removing the ABS sensor and see if anything falls out.
Just my 2 cents :leaving:
chb88 is offline   Reply With Quote
Old 01-06-2004, 01:48 PM   #15
Tourney3p0
CF Senior Member
Tourney3p0's Avatar
Default Re: Metal rubbing sound from my wheel? (Trog)
Alright guys, I went home on my lunch break and changed my rear brake pads. The sound is still there so it's not that.
I verified that I have absolutely no movement between 12 and 6 or 3 and 9, or anywhere in between. It's solid as a rock.
Good idea on the wheel sensor. I'll remove that when I get home and make sure it looks okay in there.
Here's one thing I'm not sure about.. I had to use a c-clamp to push the piston in when I was changing the brake pads. There was normal resistence with the c-clamp, but after it was pushed in I could freely move the piston in and out of the caliper with my hand. This doesn't seem like it's right to me. Is this okay or might it indicate a bad caliper?
[Modified by Tourney3p0, 12:49 PM 1/6/2004]
Old 01-06-2004, 02:03 PM   #16
bogus
CF Senior Member
thats normal... once you push the fluid out, any pressure that was holding the piston in place has been relieved.
I would also check the tires... duh... make sure you don't have any cord showing!
I hate to suggest rear diff, tho... ick.
Old 01-06-2004, 02:21 PM   #17
Tourney3p0
CF Senior Member
Tourney3p0's Avatar
If this was the case, would the sound be coming from the center of the rear? Mine is definitely coming from closer to the wheel.
How about a warped rotor? Again though, I'm not seeing any uneven wear on the rotor or the brake pad.
[Modified by Tourney3p0, 5:39 PM 1/6/2004]
Old 01-06-2004, 06:39 PM   #18
Tourney3p0
CF Senior Member
Tourney3p0's Avatar
I was able to jack up the rear end of the car and put it in neutral. It's not in my brakes at all. The sound is coming from the far end of the half shaft on the rear passenger's side.. I believe this is u-joints. I'll look to the archives and my Helms manual for further assistance.
Thanks guys.
Old 01-06-2004, 09:14 PM   #19
flyersfan1088
CF Senior Member
flyersfan1088's Avatar
Location: What did the 5 fingers say to the face? SLAP!!
Thanks guys.
I was just going to suggest U-joints. I thought mine was a bearing until I noticed a grinding noise when I jerked up on the bottom of the wheel and brought it through a range of suspension travel. Same exact noise you described when driving.
flyersfan1088 is offline   Reply With Quote
Reload this Page Metal rubbing sound from my wheel?
Tags
12, axle, car, end, makes, metal, movement, rear, rubbing, sound, sounds, trucks, turning, vertical, wheel
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 246 09-20-2012 10:41 PM
c5 coupes typically leaky? LSUgoTIGER C5 General 29 04-01-2012 06:43 AM
C6 PARTS & TECH NEWS 09-02-05 NEW INFORMATION CorvettePartsBob Ken's Newsletters 12 12-04-2005 12:59 PM
metal to metal sound from front left wheel when turning? Red5 Autocrossing & Roadracing 14 05-30-2004 10:57 PM
FEAR, ANXIETY, DEPRESSION Strick C4 Tech/Performance 11 07-24-2003 09:50 AM
Squeeking noise from left rear gaww C5 Tech 17 11-28-2002 12:56 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
