Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-26-2003, 10:41 PM   #1
Narnian
CF Senior Member
Default How do you remove door panel to fix the driver window ? 1990/91/92
I don't know how to remove the door panel! I have to get into the door to replace that plastic tape thingy that rolls the window up and down.
On my old 86 it was primarily just a bunch of screws. I don't know where to start on the 90 interior and I don't want to break anything. Anyone ever been in the door on a 90 - 92?
I think they changed the interior again in 93. Not sure. Any pointers would be welcome.
Narnian is offline   Reply With Quote
Old 12-26-2003, 11:25 PM   #2
11yellowgscpe
CF Senior Member
11yellowgscpe's Avatar
Default Re: How do you remove door panel to fix the driver window ? 1990/91/92 (Narnian)
Had mine off last summer. There are screws everywhere. In the carpet area, around the handle, the slide for the lock needs to come off. Start with the screws and pull alittle on the the panel. If it won't come in one spot check for a screw. If that doesn't work, let me know I'll look in the manual and get the specific's. The hard part was putting it back on.
11yellowgscpe is offline   Reply With Quote
Old 12-27-2003, 02:59 AM   #3
vinnies87
CF Senior Member
St. Jude '03-'04-'05-'06-'07
vinnies87's Avatar
Trick is : 1. getting all the screws out, 2. remove the door lock switch cover, 3. lift up to unhook from lip then while pulling slightly toward you slide toward the front... after 6 or 8 times its not toobad to do.. :cheers:
vinnies87 is offline   Reply With Quote
Old 12-27-2003, 10:38 AM   #4
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Support Corvetteforum!
Mr Mojo's Avatar
Send a message via ICQ to Mr Mojo Send a message via AIM to Mr Mojo Send a message via Yahoo to Mr Mojo
Marcho Polo had a pic of the panel with all the locations of the screws. I'm going of memory from my '93(which is the same).
There are 6 screws along the bottom in the carpeted area. There is one in the door jamb area(very easy to see). There is one on the front of the panel. Remove the lense in the door handle bezel, there is a screw behind that. You'll see the other screw behind the door handle. Remove the door lock slider and remove screw. On the passenger side(I never did this yet, it had alredy been removed) remove the window switch to reveal another screw. Remove the screws from the door pull area. On the drivers side, disconnect the window and power mirror switch. I think that should cover it.
Mr Mojo is offline   Reply With Quote
Old 12-27-2003, 11:15 AM   #5
Narnian
CF Senior Member
Default Re: How do you remove door panel to fix the driver window ? 1990/91/92 (Mr Mojo)
OHH! So it's still just a bunch of screws and they are disguised better. I took a cursory glance on Tuesday and didn't see any screws, but it was dark out. I thought they'd switched to those plastic pull things that usually break when you remove them. I'm going out at noon today to tackle this in broad daylight, so I'm sure it'll be easier to see the screws. If it's still just a bunch of screws then it won't be bad. Thanks for the help. I'll post again if I have trouble. I've never had to change the window motor tape before.
Old 12-28-2003, 12:57 PM   #6
vinnies87
CF Senior Member
vinnies87's Avatar
Info: Have found that the plastic screw lock pieces just break for old age.. went to pep boys and bough a bunch and replaced them when removed door panel...
Reload this Page How do you remove door panel to fix the driver window ? 1990/91/92
Tags
1990, 92, boys, corvette, door, driver, moter, panel, pep, rear, removal, remove, removing, repair, schematic, window
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
c5 coupes typically leaky? LSUgoTIGER C5 General 34 04-05-2014 12:13 PM
Weights, measurements, ratios, strengths, etc leaftye C5 Tech 252 02-02-2014 12:23 PM
C6 FAQ (Frequently Asked Questions) docrings1 C6 Corvette General Discussion 216 12-01-2010 03:33 AM
First Corvette (ZR-1) - Help with mostly minor problems csjohnson65 C4 ZR-1 Discussion 19 06-09-2005 08:21 PM
Window Motor Fix (< $5 ) mitchydkid C5 Tech 10 04-17-2005 12:08 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
