"Gutted Cats", any power gains? or just a myth?
Re: "Gutted Cats", any power gains? or just a myth? (flyersfan1088)
I will never remove cats... they are cost to much to the environment for a minor increase in performance.
If the car is running properly the lack of a converter is negligible on hydrocarbon output
Re: "Gutted Cats", any power gains? or just a myth? (smallblock)
I agree with CFI-EFI...it all depends on how cheap your cat was in the first place...modern low resistance cats only take 3-4hp...old cheapies can rob as much as 10-15...I would guess factory vette's steal about 5-6...but if you haven't maximized your headers, exhaust...cat restriction won't be your bottleneck...
Re: "Gutted Cats", any power gains? or just a myth? (TA)
I remove cats for a second reason, the amount of heat they put out. The pre-cats are close to the motor and trans, the main near the seats. By getting rid of these, the car runs much cooler. Not all cars have trouble with heat, and yes, a modern cat in good order won't affect flow much. But an old, clogged, or poorly placed cat has to go! People like us keep our cars in good running order, so the pollution is not a concern.
my .02 :smash:
[Modified by Gearheadotaku, 7:34 AM 12/26/2003]
my .02 :smash:
1 Post
Re: "Gutted Cats", any power gains? or just a myth? (Gearheadotaku)
I have never had a gutted cat car not pass emissions. Cats are just govt mandatred fail-safe devices for dopey people(obviously no one on this board ) who never change their oil or plugs. With LCD (lowest-common-denometer)actions like this the 95% pay for the foolishness of the 5%
But it looks like the tree hugger propoganda is working fine :jester
Re: "Gutted Cats", any power gains? or just a myth? (HiRiser)
With LCD (lowest-common-denometer)actions like this the 95% pay for the foolishness of the 5% :jester
Re: "Gutted Cats", any power gains? or just a myth? (WardVette)
I once read somewhere that the pollution caused by the manufacture of a CAT is greater than the pollution reduced by the CAT in its service life
I am cynical old and grumpy enough to believe it.
"Gutted Cats", any power gains? or just a myth? [scorp508]
And I will post again my gains.
Stock (with a brand new main cat): 13.89 @ 98.17 (Was usually 13.9x though)
Then...
1. Gutted main cat (still had the precats)
2. Flowmaster mufflers
3. AIR pump elimitator
Went 13.48 @ 101.11
Then...
Went 13.48 @ 101.11
Re: "Gutted Cats", any power gains? or just a myth? (britvette)
:iagree:
1 Post
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Re: "Gutted Cats", any power gains? or just a myth? (NASCAR314)
Hell i just removed the precats and went with a aftermarket high flow Y pipe and cat and no mufflers .I just passed state emissins inspection on theier dyno with flying colors my car was putting out 1/4 of the emissions spec that it can and still pass.ill Post my spec sheet later this week.
Re: "Gutted Cats", any power gains? or just a myth? (crash1mac)
Cool to know, I had my precats gutted, one of them had broken on the inside and was ratling.
They just re welded the pre cat shut after gutting them.
I was told they are mostly for the resonnance, not as much for polution.
#33
Re: "Gutted Cats", any power gains? or just a myth? (TheStef)
Just get rid if the pre-cats and the cat...weld in their place aluminum pipe...Huge seat - of the -pants feel in power, and for the first time, she sounds like a real sports car. Dump the factory mufflers and purchase a set of aftermarket mufflers... :thumbs: Then you will not only run better, but you will sound the way a Corvette was meant to sound... :thumbs:
#34
Location: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
I did it, and did I notice a big difference in ET's and mph.
#35
Location: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Re: "Gutted Cats", any power gains? or just a myth? (89NYFINESTVETTE)
I removed mine and put 2 straight through pipes on for $50. It has been the best/cheapest Mod I have done so far. Too bad for California people :nopity
#36
Aloha,
Larry
#37
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Re: "Gutted Cats", any power gains? or just a myth? (CFI-EFI)
Don't forget that the "buttometer" is monitoring both your wallet and the jar of Ben Gay. The harder the job, the longer it takes or the more it costs, the greater the "buttometer" readings. I should have gotten a full second off my ETs with the heater core change.
:iagree:
Truer words have never been spoken.
:yesnod:
:iagree:
:yesnod:
#39
I think alot of your gain will depend on if your car has single or dual cats - dual cats flow pretty good. The factory claimed 10 horse for the dual cat L98 F-body over the single cat cars. I had a 383 TPI TransAm a few years ago that made 339 rwhp through dual random technology high flow cats. On open headers it made 346 rwhp - only 7 horse - but that's a seriously modified motor - and that measurement also included loss through the muffler. A stocker would probably only make 5 or less - unless it was a single cat car to begin with. Also, if you do it - I'd put in a straight pipe - a punched out converter may create some added turbulence in the gas flow due to changing cross-sectional area compared to the pipe - the area expands as the gas enters the hollow converter & then contracts again as it leaves the converter. That effect may hold you back from maximizing your already small gains.
KC :cool:
KC :cool:
#40
1 Post
St. Jude Donor '05
CI VI Veteran
Re: "Gutted Cats", any power gains? or just a myth? (mistaben)
I agree with the statement it is a cost much to high to the enviroment.
Hydrocarbons were at 2.2ppm (out of an allowable 220 ppm)
These motors burn SO clean that even with the stuff removed, they are cleaner than 99% of the cars from the factory.
Even the LT1 that's built in my '95 vert with cats gutted blew through the inspection...
Mark
