Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-20-2003, 12:41 PM   #1
dizwiz24
CF Senior Member
Default How do I 'set' the TPS and IAC...93 LT-1 ?
Someone mentioned they set their TPS and IAC and their car has never run better. I asked them how to do it, and they never responded back.
Recently I put a new TPS sensor in, at WOT the new TPS registered 4.06 volts which showed 99% throttle position on my Auto XRay scantool.
However, my old TPS sensor showed 4.62 volts at WOT and 99% throttle position on my auto xray.
I figure I might be 'ok' because it still shows 99% throttle (somehow my ECM learned that 4.06 volts meant WOT)
However, I am still curious as to how one 'sets' both IAC and TPS
I should mention my car always seems rich, with its current mods, at idle.
I have a 93 LT-1 w/hot cam kit, ed wright chip, LT headers, no cats.
Any help would be appreciated,
Dave
dizwiz24 is offline   Reply With Quote
Old 12-20-2003, 01:02 PM   #2
ittlfly
CF Senior Member
ittlfly's Avatar
Default Re: How do I 'set' the TPS and IAC...93 LT-1 ? (dizwiz24)
I think your TPS is the same as the one on my 92. In which case, it is non- adjustable. According to the Helms, it is self zeroing (0% open at idle) at .3-.9v. ...it does mention that if a new TPS is installed, the TECH 1 unit (@ the dlr unless you just happen to have one around the house :D ) will reset it for ASR functions.
[Modified by ittlfly, 10:28 AM 12/20/2003]
ittlfly is offline   Reply With Quote
Old 12-20-2003, 01:11 PM   #3
65Z01
CF Senior Member
Cruise-In II Veteran
65Z01's Avatar
Send a message via AIM to 65Z01
The methods for setting IAC & TPS are on my site (link in sig. below) but, as mentioned, your TPS is not adjustable though the ECM still uses OBD-I.
Beginning in '90, even if you cut adjusting slots into the TPS mount the ECM will simply override any "tweaks".
65Z01 is online now   Reply With Quote
Old 12-20-2003, 04:02 PM   #4
dizwiz24
CF Senior Member
Default Re: How do I 'set' the TPS and IAC...93 LT-1 ? (65Z01)
65Z01 I cant see your signature, can you post the link.
Old 12-20-2003, 04:19 PM   #5
Goody
CF Senior Member
Goody's Avatar
diz, TPS is not adjustable as mentioned earlier. However IAC is adjusted by the following. Pg 6E3-C2-5 (VIN P):
The IAC valve can be reset by doing the following: depress accelerator pedal slightly, start and run engine for five seconds, then turn ignition "off" for ten seconds.
Goody is offline   Reply With Quote
Reload this Page How do I 'set' the TPS and IAC...93 LT-1 ?
Tags
93, corvette, iac, set, tps
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Finally got a chance to get rowdy with my car. dtorc4 C4 General Discussion 9 12-18-2003 11:50 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
