Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-19-2003, 01:17 PM   #1
shotchkiss
CF Senior Member
shotchkiss's Avatar
Default Harmonic balancer removal question - how to get bolt loose? (L98)
L98 motor. What is the best way to stop the motors from turning over when trying to remove the bolt in the center of the balancer? When I try to unscrew it, I keep turning the crankshaft instead. Can I just put a pair of vice grips on the flywheel to hold it, or is there a better way? I have an auto transmission.
shotchkiss is offline   Reply With Quote
Old 12-19-2003, 01:28 PM   #2
65Z01
CF Senior Member
Cruise-In II Veteran
65Z01's Avatar
Send a message via AIM to 65Z01
Default Re: Harmonic balancer removal question - how to get bolt loose? (shotchkiss)
If pressing on the serpentine doesn't give enough resistance you might try putting three bolts into the three crank pulley holes and use a bar across them to hold the carnk from turning as you break the center bolt free.
I have a pulley puller set and have used the three hardened bolts from that set effectively.
65Z01 is offline   Reply With Quote
Old 12-19-2003, 01:40 PM   #3
shotchkiss
CF Senior Member
shotchkiss's Avatar
Default Re: Harmonic balancer removal question - how to get bolt loose? (65Z01)
Can't do the belt thing because everything is off the front of the engine now, will try some longer bolts. That center bolt has to come out before the pulley will come off, correct?
Old 12-19-2003, 01:45 PM   #4
89 Iroc Z
CF Member
The easiest way is to use an impact wrench. I donít have one so I had to of my friends hold the pulley while I broke the bolt loose.
89 Iroc Z is offline   Reply With Quote
Old 12-19-2003, 01:56 PM   #5
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
This CAN get tricky. The bolts in the pulley holes can work, but because you can't remove the pulley, the bolts have to be pretty long. They are likely to get bent if the center bolt is tight enough. I tried one of those rubber strap wrenches around the outside of the damper, and it broke the strap, instantly. A lot depends on what else you may be doing besides removing the damper. The lsat time *I* did this I was changing the bearings in the engine. I just waited until the pan was off and used a crowbar to prevent the crank from turning. The vise grips on the flexplate ought to work, OK if you are planning to remove the converter cover. If the starter is going to come out, you could hold the flexplate with a prybar or large screw driver. If all you are doing is removing the damper, probably the easiest way would to feed some rope into a spark pug hole. Then just turn the engine over until it binds up on the rope. Of course if you have air available and room for the impact wrench, you don't have to worry about holding the crank from turning. Good luck, and...
RACE ON!!!
CFI-EFI is offline   Reply With Quote
Old 12-19-2003, 02:57 PM   #6
hippy
CF Senior Member
Actually I don't think it does. Been a few years since I did mine. But I don't recall pulling that bolt.
hippy is online now   Reply With Quote
Old 12-19-2003, 03:13 PM   #7
Bluevette85
CF Senior Member
Bluevette85's Avatar
Default Re: Harmonic balancer removal question - how to get bolt loose? (hippy)
Yes it does on the L98 :yesnod:
Bluevette85 is offline   Reply With Quote
Old 12-19-2003, 03:35 PM   #8
gregfloyd
CF Senior Member
Default Re: Harmonic balancer removal question - how to get bolt loose? (Bluevette85)
A trick i use somtimes is to get a socket and a long breaker bar. Then i give the breaker bar a good whack with this heavy ole lead mallet i have.
gregfloyd is offline   Reply With Quote
Old 12-19-2003, 03:41 PM   #9
hippy
CF Senior Member
Maybe it does, like I said it's been a few years. :crazy:
Old 12-19-2003, 05:47 PM   #10
JAKE
CF Senior Member
JAKE's Avatar
When I have that problem I attack the other end of the engine. I have someone wedge a long handle heavy screwdriver between the teeth of the flexplate and the transmission bell housing; then I give the bolt a heavy, but sharp turn. A really long steel pipe placed on the ratchet handle will give you more leverage for a sharp pull/push.
When I'm alone (or can't convince anyone to crawl under the car), I find a way to wedge the screwdriver and leave it there. I then crawl out and do the bolt loosening.
Another way I've done in the past is to let the starter break the dampner bolt loose. I use a 1/2" ratchet and socket, put the socket on the bolt and bump the starter. In cases where the ratchet handle isn't long enough to lock onto a suspension point, I attach a piece of steel tubing on the ratchet handle so that it can reach some really solid point.
Gotta be careful with that trick though; just a bump is all you'll need
A desperate man will tryabout anything. lol.
Hope this helps.
Jake
[Modified by JAKE, 4:48 PM 12/19/2003]
JAKE is offline   Reply With Quote
Old 12-19-2003, 06:16 PM   #11
65Z01
CF Senior Member
65Z01's Avatar
Default Re: Harmonic balancer removal question - how to get bolt loose? (JAKE)
I well know about that "derparate measures" thing. Years ago I used the "starter bump" to break a damper bolt loose but wouldn't try it today.
Guess I've gotten a bit conservative with age. :lol:
Old 12-19-2003, 10:31 PM   #12
shotchkiss
CF Senior Member
shotchkiss's Avatar
Got the bolt out finally. Pulled the radiator out and got it with a borrowed impact wrench, really had to crank up the pressure on it and it took a few minutes, but it finally rattled loose. Since I'm doing a cam change, the radiator had to come out anyway, so that didn't bother me. Lots of crud under it also, so a good time to clean it out. Thanks for the help.
Old 09-25-2011, 01:26 AM   #13
wburgle
Junior Member
I just saw a vidio on another sight, they removed a spark plug, then inserted some nylon rope to block the rotation of the engine. Still need a lot of leverage on the breaker bar. Then remove the rope. I'll try it next time I get stuck.
c5 bill
wburgle is offline   Reply With Quote
Old 09-25-2011, 04:53 AM   #14
rodj
CF Senior Member
rodj's Avatar
Quote:
Easiest way if engine in car.
Also works to hold valves up if doing valve spring change and not having compressed air available
rodj is offline   Reply With Quote
Old 09-25-2011, 08:01 AM   #15
1963SS
Over 500HP Club
Support Corvetteforum!
1963SS's Avatar
Still works the same way. I've "seen" it done many, many times.
1963SS is offline   Reply With Quote
Old 09-25-2011, 07:41 PM   #16
l98tpi
CF Senior Member
l98tpi's Avatar
Bob Armstrong
Impact
l98tpi is offline   Reply With Quote
Old 09-28-2011, 02:45 PM   #17
muzikmanwi
CF Senior Member
muzikmanwi's Avatar
8 year old thread guys
muzikmanwi is offline   Reply With Quote
Reload this Page Harmonic balancer removal question - how to get bolt loose? (L98)
Tags
98, balancer, balancing, balencer, bolt, c6, chevy, corvette, hamonic, harmonic, hrmaonic, loose, lose, lt1, motor, removal, turning
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
