cast of forged, just learning
Really stupid question, I know what cast metal is less strong
then forged steel.
But what process do thye take to create forged parts and cast pasts?
what makes forged part so much stronger?
then forged steel.
Re: cast of forged, just learning (TheStef)
Stef: A little Metal Shop 101.... cast parts start as molten (melted) metal shaped first by pouring, injecting, etc. Forged parts are either cold or hot when forged. This is basically a hammering into shape(like a blacksmith making hosreshpoes, etc. The hammer cab ebe just that or a huge multi ton machine capable of great striking force. The forging re-aligns the molecular structure of the metal thus giving it properties that are different/applicable to the part use. Crankshafts and pistons can be either cast or forged. Forged being able to withstand more punishment.
Received 1,425 Likes
is this the same with connecting rods also?
Cruise-In I Veteran
Cruise-In II Veteran
Let's complete the lesson by discussion of Billet VS Cast VS Forged. Grain structure etc. Someone less lazy than moi?
Re: cast of forged, just learning (timallard)
hyper is in between cast and forged in strength, but not much better than cast for forced induction
its basically a cast piston with high silicon content added to the aluminum alloy, it is a good piston for high rpms compared to cast because of its thermal properties
Hypereutectic refers to the alloy it is made out of, not the means that it is made. Hypereutectic means it's an Aluminum Silicon alloy with more than about 12% Silicon (12% would make it Eutectic, and less would be Hypoeutectic). It's a very strong alloy, but rather brittle...
Re: cast of forged, just learning (Darcane)
Well that certainly increases my basic understanding of these terms. Thanks. While we're learning, could someone define CNC for me? :cheers:
Re: cast of forged, just learning (86Moon)
Witch one is the strongest?
And If I understand Hypereutectic is a simple cast piston with added silicon/aluminum to make the metal stronger, a bit like adding carbon to steel to make it stronger.
What about Titanium parts? do they exist in engine parts? it seems only logical that the big HP engines would benefit from this type of metal since it is stronger then steel.
I know one of my friends had Titanium parts custom made for his Skydoo, engine. Has any one on the forum even done something like this? or do any company sell these parts?
Location: Brandywine, Chester and Ridley Valleys Pennsylvania
Valvetrains are the main area that any of us "regulars" would even think to use titanium. Price a set of regular retainers vs. a set of titanium ones and see why it's price-prohibitive for "regular" cars like us to use titanium for much of anything.
The NSX's used titanium rods if I'm not mistaken. To handle the sky-high revs I guess.
CNC = Computer Numerical Control. A "CNC" machine is one one that uses a punch tape to tell it what to do. Parts made on a CNC machine are supposed to be identical. We often hear the term as applied to cylinder head porting. Once a porter experiments and reaches a shape he likes, the port can be mapped. The cutting process can then be automated on a CNC machine station so all the ports are the same as the proven port. It eliminates the "human" factor in the duplication process, not to mention man hours of labor.
Head porting companies use this technology now because they can set the program up to mill exactly what they want from any particular head. Unlike "old hand porting" that can differ from port to port, a CNC'd head will have the same exact tolerances in each port if programmed to do so. It does require changing the cutting elements after so many passes to make sure quality work is still produced.
[Modified by Goody, 11:43 AM 12/12/2003]
Whtch one is the strongest?
A forging starts with a real honest to god billet and whomps it into shape. In a well designed forging the granular structure of the material get arranged in a way that increases that parts strength and more importantly it's toughness. And a very important point, forging quality control is easier than high strength casting quality control. The chances of a forging fully performing to it's material spec is much higher than a casting doing the same.
see: http://www.qcforge.com/defin1.html
"Billet" is an aftermarket parts marketing term for "machined from one piece of metal" I've even seen Hogly Ferguson "billet" parts that were machined form castings:lol: "Billet" parts are almost always machined from one solid, finsihed chunk of metal, usually not a true billet. They usually start with plate, bar or an extrusion A real billet is a semi finished chunk of metal that is normally used in forgings or other forming operations such as rolling or extruding before anything is made from it.
For casting, a bunch of molton metal is pured or forced into a mold of some type. Castings are usually but not always weaker than forgings or "billet" parts. High quality high strength casting take good, expensive, equipment and a lot of good, expensive expertise to make. Even at their best, castings tend to not be as forgiving as forgings and are more likely to break if severly overloaded.
What about Titanium parts? do they exist in engine parts? it seems only logical that the big HP engines would benefit from this type of metal since it is stronger then steel..
[Modified by xs650, 10:46 AM 12/12/2003]
6th Gear
Re: cast of forged, just learning (xs650)
Recently I was reading about forged cranks and cast cranks. I read there were incidents where forged cranks were snapping. I read there was a discussion that possibly cast cranks had a dampening affect that forged cranks lacked. But this was all theory and couldnt be proven.
Re: cast of forged, just learning (shaggy56)
....I read there were incidents where forged cranks were snapping. I read there was a discussion that possibly cast cranks had a dampening affect that forged cranks lacked. But this was all theory and couldnt be proven.
I know I'm the one asking quesions here, but I did read something about that somewhere.. I can't remmeber were though??
You gotta work pretty damn hard to break a crank.
If its installed right.
