Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-07-2003, 07:54 PM   #1
oldace84
CF Senior Member
St. Jude Donor '04 & '05
oldace84's Avatar
Default Whats the best tranny fluid 700R4 To use?
Like the B&M, or what my trans was rebuilt 20k miles ago.
Am using an after market kooler, along with A Dearl Pan, 1 1/2 more quarts of fluid. Dearl Pan from Jegs.
Please lwt me know.
thank you
tony
:flag
[Modified by oldace84, 4:55 PM 11/7/2003]
oldace84 is offline   Reply With Quote
Old 11-08-2003, 02:47 PM   #2
FostersPerformance
CF Senior Member
FostersPerformance's Avatar
Default Re: Whats the best tranny fluid 700R4 To use? (oldace84)
Well you can ,
A) stick with clean ATF recommended fluid, and change intervals
or,
B) get verybit of fluid you can outta it, and run stright B&M Trick Shift. I ran this stuff for 4 years in my 700r4 '83 Z28 450HP street daily, and it was a happy tranny!!! :D
C) Listen to all these yuppies, and buy 10$ a qt synthetic,ultra slick, BS tranny fluid that offers little signifigance....
Thats my 2 cents , but i speak from experiance.
FostersPerformance is offline   Reply With Quote
Old 11-08-2003, 03:19 PM   #3
1990CORVETTE
CF Senior Member
1990CORVETTE's Avatar
Here I go again.......
Royal Purple :cheers:
1990CORVETTE is offline   Reply With Quote
Old 11-08-2003, 03:49 PM   #4
myscx
CF Senior Member
myscx's Avatar
MOBIL 1 ATF :thumbs:
myscx is offline   Reply With Quote
Old 11-08-2003, 04:32 PM   #5
TreyZ28
CF Senior Member
TreyZ28's Avatar
Send a message via AIM to TreyZ28
In the 4L60e, use fords Dectron V thing.
I know a GM test engineer personally, his job is to blow up transmissions for durrability tests. Fords fluid lasts the longest. Synthetic is a terrible choice for the 4l60E, it can actually decrease life.
add a big cooler and call it good :thumb:
TreyZ28 is offline   Reply With Quote
Old 11-08-2003, 04:40 PM   #6
Mad-Mic
CF Senior Member
Mad-Mic's Avatar
Send a message via AIM to Mad-Mic Send a message via Yahoo to Mad-Mic Send a message via Skype™ to Mad-Mic
Default Re: Whats the best tranny fluid 700R4 To use? (TreyZ28)
i run valvoline synethetic ATF in my 700R4. runs good and shifts hard! :)
Mad-Mic is offline   Reply With Quote
Old 11-08-2003, 05:28 PM   #7
smallblock
CF Senior Member
red line.......
smallblock is offline   Reply With Quote
Old 11-08-2003, 06:09 PM   #8
Corvette0096
CF Senior Member
Corvette0096's Avatar
Send a message via Yahoo to Corvette0096
Default Re: Whats the best tranny fluid 700R4 To use? (smallblock)
:iagree:
Corvette0096 is offline   Reply With Quote
Old 11-08-2003, 09:10 PM   #9
Alex D
CF Senior Member
Alex D's Avatar
Default Re: Whats the best tranny fluid 700R4 To use? (Corvette0096)
I swapped the stock fluid out at 24,000 mls. for Mobil 1 Synthetic ATF. It made the shifts a lot smoother than with the stock fluid.
After all what I read I would probably buy genuine GM ATF Dexron III ($2.60/qt. here at my dealer) and change it every 20,000 miles.
Alex D is offline   Reply With Quote
Old 11-09-2003, 12:23 AM   #10
ENGINE TROOP
CF Senior Member
ENGINE TROOP's Avatar
Send a message via AIM to ENGINE TROOP
Default Re: Whats the best tranny fluid 700R4 To use? (Mad-Mic)
any dextron III
the cheaper the better, this way you can change it more often
I use valvoline but not the synthetic.
rather than spending 2 or 3 times as much on synthetic, you are better off changing it 2 or 3 times more often.
because no matter what brand it is, once it is burnt, its junk.
ENGINE TROOP is offline   Reply With Quote
Reload this Page Whats the best tranny fluid 700R4 To use?
Tags
700r4, atf, best, chevrolet, fluid, fluids, fluild, mobil, mobil1synthetic, oil, redline, synthetic, top, tranny, transmission, whats
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
