1984 rear height uneven
While detailing the 84 yesterday, I noticed the rear left tire was close to the body of the car. I was able to place two fingers between the tire and body. On the right side of the car I was able to place three fingers between the tire and body. It appears the right side is slightly higher then the left. From the rear you can't notice it. I recently replaced the half shaft u joints. I followed a tech tip on half shaft u joint replacement and counted the threads on the leaf spring bolt. Upon completion of the u joints, I tighten the nut to reflect the number of threads I counted. Is this how you adjust the rear height of the car?
[Modified by Brimis, 7:45 PM 10/26/2003]
