LT1 Breaking up/ sputtering BAD at high rpm's ---HELP
Re: (scorp508)
It'll be a lot harder than your Chevelle, I'll tell ya that. I haven't done an LT1 yet
Scorp...you haven't done an LT1 YET ...there's a first time for everything!! Come on down! :jester
Best plug / wire choices?
Is the coil change a pain too...or should I swap a new one in while I'm at it. Which coil to use??
Thanks for all the help guys. I appreciate it! :cheers:
-Rick
[Modified by cicch95, 11:08 PM 10/19/2003]
Re: (cicch95)
So....how hard is this plug / wire job going to be? Any tips for a rookie "Vette mechanic". :)
Having a couple beers while doing the job helps too. :cheers:
I also agree changing plugs, wires and maybe fuel filter first all cheap stuff first. Those things could potentially be the problem as well. Then move onto looking into bigger things if that doesn't work. (4 letter word)
Re: (KyleBst264)
-Rick
Re: (cicch95)
So....how hard is this plug / wire job going to be? Any tips for a rookie "Vette mechanic". :) -Rick
Replace ONE wire at a time to avoid confusion.
Use the dielectric grease in the boots, just don't get it on the tips or on the plug connections since it inhibits electron flow.
Be careful around the wire looms as they are likely fragile and easy to break.
Be very PATIENT.....have plenty of time so you aren't rushed.
:banghead: :banghead: :banghead:
Re: LT1 Breaking up/ sputtering BAD at high rpm's ---HELP (cicch95)
90% sure it's not your Opti (but there's a chance)....90% sure you need plugs and wires. I've seen this on a couple of LT-1's now, including mine. Identical symptoms. Stick a new, properly gapped set of NGK TR-55s in and try it.
:cheers:
:cheers:
Re: LT1 Breaking up/ sputtering BAD at high rpm's ---HELP (Atok)
-Rick
With a solid idle, I would have to blame plugs and wires...
Oh, get Taylor wires. They are da bom!
Re: LT1 Breaking up/ sputtering BAD at high rpm's ---HELP (bogus)
A couple of things...The plugs a on the pass side on the 92 are snap. On the drivers side, some guys pull the center inner fender well (where the ASR box attaches to). About 6 bolts and a wire loom and its out. That will open it up so you can get the plug wires under the compressor. I just pulled the compressor and (4 bolts) and laid it on top. if you remvoe the belt and its tensioner (1 bolt) that will make it a snap. A/C calls for .50 gap.......
On the coil / coil driver, its straight forward. A little tight due to the power steering resv....just lift it off the perch and lay it aside (right side up :D )..and DO NOT REMOVE the special white grease on the mounting plate unless you have some more. Hope this helps. :cheers:
Re: LT1 Breaking up/ sputtering BAD at high rpm's ---HELP (ittlfly)
Thanks for the tips guys! I really hope this is my probem and not the "XXXX" :mad
-Rick
-Rick
-Rick
-Rick
:flag
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Re: LT1 Breaking up/ sputtering BAD at high rpm's ---HELP (konroh)
I've got a slight miss at idle with my LT1, too. Gonna' drop in a set of TR55 NGK Copper Cores and see if that takes care of it. No problems with WOT or under load near redline like you're describing, though.
My AutoLite platinum plugs have more than 18,000 miles on 'em, so it's probably time for a swap.
Re: LT1 Breaking up/ sputtering BAD at high rpm's ---HELP (onedef92)
low rpm miss indicates carbon tracing in the cap/rotor.
#33
Check to see if any codes are set. You may have an ignition module going bad as well.
1. Check to make sure the fuel pressure is staying up (the cutting out may be detonation or lack of fuel)
2. Wires
3. Plugs
4. Coil
5. Opti
There are a couple other things that can cause it, but the list above with get 95% of the causes of the problem you describe.
2. Wires
3. Plugs
4. Coil
5. Opti
#34
Re: LT1 Breaking up/ sputtering BAD at high rpm's ---HELP (Vette92)
check your email, i can help you pull the plugs and wires and coil, fri night and/or sat morning. We'll get it running like it should then the 91 L98 vert Vs. 92 LT1 vert race can commence LOL :cheers:
#35
Re: LT1 Breaking up/ sputtering BAD at high rpm's ---HELP (robertpel9)
See ya friday! Anyone else out there want to lend a hand and drink some beers?? LOL :cheers:
-Rick
#37
technically, they should not.
