opti miss at high end?
Has anyone ever had there opti only miss in upper rpm's? The dyno shop told me that the car had a miss @5200 on one pull and ~4500 on another. They suggest changing the plugs, which I will, but I am pretty sure its probably the damn opti. Therefore no real tuning was ablr to be done on my car. :cry
Elite Torch Red Member
Re: opti miss at high end? (87Z-ya)
Yes it has happened to me, on my '95 it was the wire from the coil rubbing the waterpump, on my '93 it was the opti.
I had this occur. The miss was present only above 6000rpm and it was intermitent.
Re: opti miss at high end? (96GS#007)
Yep, had it on my Opti too. Installed the LTCC and no more missing at WOT shifts. Need a dyno run now to see if it really holds all the way to redline.
